Thread started 29 Mar 2010 (Monday) 13:59
How to achieve this look
msfvirginia
Mar 29, 2010 13:59 |  #1
I was surfing around and I came across this image. It looks almost 3d, and Id really like to be able to recreate this look using photoshop, assuming its possible.
http://hphotos-snc3.fbcdn.net …20_31085573_361​8919_n.jpg (external link)
I suppose it could be a sketch
krb
Mar 29, 2010 14:05 |  #2
I've seen similar effects from careful adjustments to contrast, exposure and sharpness.
Starting from a shot that had good exposure and lighting is of course a requirement.
-- Ken
Gear list
ethos101
Mar 29, 2010 14:23 |  #3
I would think to convert to black and white then play with the individual R, G and B components of the image. Just my guess.
"A photograph is usually looked at - seldom looked into." - Adams http://danhardyimages.​com (external link)
Permagrin
Mar 29, 2010 14:31 as a reply to  @ ethos101's post |  #4
it would probably be best to convert that image to a link to the original gallery where you found it. It's against the rules to post someone else's photo.
It looks like a psuedo hdr converted to B&W
spinney
Mar 29, 2010 14:38 |  #5
Well if you use lightroom or ACR and you have a properly exposed shot preferably in RAW format you could crank the fill the blacks and clarity sliders, adjust exp, brightness, recovery and contrast to taste. Also crank the Vibrance, and drop saturation down low around 5,to drop out the color and if you want to play with the overall mix of tones after converting to BW play with the WB settings!
Randy Spinney Photography (external link)
http://www.facebook.co​m …otography/14193​6862570730 (external link)
Keith ­ R
Mar 29, 2010 14:51 |  #6
Looks like Dave Hill-style processing then a b & w conversion.
Rob ­ Wilkinson
Joined Sep 2009
Mar 29, 2010 14:53 as a reply to  @ Keith R's post |  #7
Looks like a heavy high-pass filter, maybe set to hard light?
I'd guess the original also got some (read: a lot) clarity slider as someone else mentioned.
Come have a look: http://www.resolutionp​hoto.net (external link)
msfvirginia
Mar 29, 2010 15:40 |  #8
Thanks for the replies everyone. Ill have to play with this information.
Im not sure how much raw editing I can do, im using Digital Photo Professional that came with my canon camera's. I dont have lightroom yet because im still using Photoshop CS1.
TheArtfulBurner
Mar 29, 2010 21:01 as a reply to  @ msfvirginia's post |  #9
Some of the above suggestions will get you into similar territory. You might also try Topaz Detail. Another technique is to process normally in ACR and then in PS create a duplicate layer, invert that layer, set it to vivid light, add a gausian blur close to the max. Ctl+shift+alt+e, delete the layer set to vivid, set top layer to overlay and adjust opacity to taste. Can create amazing sharpness without halos if you learn how to adjust the gausian blur part.
Sussex photographer (external link)
DaveH76
Mar 30, 2010 05:17 as a reply to  @ TheArtfulBurner's post |  #10
Looks like a B&W conversion of a faux HDR to me.
5DmkII, 450D - 18-55mm IS, 20mm F2.8, 24-70mm F2.8 L, 50mm F1.8, 70-200mm F4 L, 100mm F2.8 Macro
FLIKR (external link)
dugcross
Mar 30, 2010 07:26 as a reply to  @ DaveH76's post |  #11
I've done some b&w hdr that had this result. Giving it an almost sketched look.
Doug Cross
Graphic Designer and Photographer
www.crossphotographics​.com (external link)
1,528 views & 0 likes for this thread, 10 members have posted to it.
Latest registered member is slipper1963
1861 guests, 162 members online
