Thread started 29 Mar 2010 (Monday) 15:13
Another 24-70 vs 24-105 thread
CalPiker
Mar 29, 2010 15:13 |  #1
So after many months and switching between wanting to get the 24-70 or the 24-105, I finally decided to rent both and make a comparison. I just could not make up my mind on which one to get. Just when I thought I wanted the 24-70, because I already have the 70-200 (didn't need the 70-105 part), I changed my mind because of the IS on the 24-105. I don't do a lot of indoor, low-light shooting, which for some reason people think that's all the 2.8 is good for (based on some other posts. I guess it is good for them, but not me). Getting the shallower depth of field was kind of important, but I do have the 50 f1.8 if I need it. Weight wasn't a concern for me and the prices are only about $100 difference.
So I have been going back and forth between the two and it has been driving me nuts. The thing I think I might miss most is not having these lenses be wider than they are. I'm going to get one of them to replace my 18-55 kit lens (could possibly upgrade to 5D soon). I have found that I use 18mm a lot. But I have been shooting with the kit lens at 24mm for some time just to see how much I would miss it. Maybe a little bit. Which this now puts me in another dilemma - 16-35 or 17-40 as my next lens. What a terrible problem to have, right? :)
Right now, I think the IS is the determining factor for me to get the 24-105 over the 24-70. I don't normally shoot people, so I'd like to be able to use this at slower shutter speeds than 1/FL with that little extra help. I'm definitely going to do some comparison testing between the two lenses at times when I would normally shoot (I do a lot of sunsets, so I will have to see how the IS vs 2.8 compares. See my Smugmug link in my sig for what I like to shoot). Wish me luck, because I think at the end of my rental period I will still have a problem deciding.
Can I take your picture? "I'll swallow your soul!" Well, my camera will at least.
FuturamaJSP
Mar 29, 2010 15:17 |  #2
I can bet a hundred bucks on that within the next 5 replies someone is going to try to talk you into getting a ef-s 17-55 :rolleyes: :rolleyes: :rolleyes: :rolleyes:
Seriously though I had the very same dilemma before I bought the 24-70L and I am very happy with it mainly because of it's wider aperture. I just love the bokeh and shallow dof created by that lens. I have had a nifty fifty believe me the brick totally outperforms it even though it's like one and a half stops faster.
They asked me how well I understood theoretical physics. I said I had a theoretical degree in physics. They said welcome aboard! - Fallout New Vegas
blah blah blah
DA (external link)
Jerobean
Mar 29, 2010 15:23 |  #3
hmm, why would you shoot a sunset at f2.8?
seems for you a 24-105 is the answer. If you need to shoot indoors, get a flash or get a fast prime.
6d, 24-105L, Tak SMC 50 1.4, 85 1.8, 135L
GilesGuthrie
Mar 29, 2010 15:25 |  #4
I have both. 24-70 is, for me, a "people lens". Whereas 24-105 is a "scenery lens". A lot of people think that low light automatically requires wide aperture, but if you're being a tourist, you don't want the narrow DOF that wide aperture necessitates.
Blipfoto (external link) - Flickr (external link) - Twitter (external link)
Canon EOS 1d X, 1d MkIII, 5d. Gear List
CalPiker
Mar 29, 2010 15:26 |  #5
FuturamaJSP wrote in post #9894704 (external link)
Haha, yeah. That's why I put in there that I would probably upgrade to the 5D soon. I don't need another lens I can't use! :)
chadmyers
Mar 29, 2010 15:36 |  #6
I have the Canon 5Dmk2 and the 24-70 and use it for weddings and I love it! Works great in low light, and i'm sure the 5dmk2 helps!
chad
Chad
DM Studio2 Photography (external link)
Columbus Ohio Wedding Photographer (external link)
tisun
Mar 29, 2010 15:37 as a reply to  @ CalPiker's post |  #7
I think you need both. :) I used to have a 24-70 and used it for indoor, kids, and walk-around lens. It was too damn heavy as a walk-around lens and I wasn't using shallow DOF much so I traded for a 24-105 IS. Indoor shots of people with flash was a tad sharper because of IS. As a walk-around lens, it's great. However, I found I missed the shallow DOF so I got a 50mm f/1.8. The 50mm lens is too slow in focus and misses focus more frequently than the 24-70. Now I miss the 24-70. :(
the ­ phelp
Mar 29, 2010 15:37 |  #8
I went through the same thing, and ended up with the 24-70. Depth of field was a big factor, but also consider that shooting in anything but bright sunlight can push your ability to get a desirable shutter speed for a moving subject. I spent a couple hours shooting running dogs in overcast weather yesterday, and the extra aperture was helpful.
->Mike
Gear List: 7D; 40D; 10-22; 24-70; 50/1.4; 100/2.8; 135/2; 100-400; 580ex; MT-24
my zenfolio (external link)
iFloyd
Mar 29, 2010 17:12 |  #9
the phelp wrote in post #9894840 (external link)
same here, my 24-70 is my go-to lens
gear | flickr (external link) | blog (external link) | website (external link)
Deep ­ Pocket
Mar 29, 2010 17:24 |  #10
I don't find the slight extra reach and IS of the 24-105 justifiable to give up f/2.8. F/2.8 can be very useful in isolating subjects. If you really want something slightly longer just pick up a 70-200.
On the other hand, I find it perfectly justifiable to get the 24-105 and just a fast prime for subject isolating and low light. f/2.8 is no means a miracle and a lot of the time it's not enough for any indoor work without high ISO, or not enough to isolate much. Your option here would be a 24-105 and perhaps something like a 50 1.4 / 135 2.0
17 and learning..
Canon Rebel XSI/450D:
Sigma 30 f/1.4, EF-S 55-250mm f/4-5.6 IS, 18-55 Kit Lens
Deviantart (external link)
PrimeGlass
Mar 29, 2010 17:37 |  #11
I kept both the 24-70 and 24-105. It was hard to justify at first but it makes the most sense in the end. The 24-70 is great for portraits, lower light shooting, better isolation, etc. but its too heavy and short for me when travelling.
5D MKII I 1D MKIII GEAR LIST & FEEDBACK
xarqi
Mar 29, 2010 18:07 as a reply to  @ PrimeGlass's post |  #12
Excellent suggestion since ...
CalPiker wrote in post #9894675 (external link)
CalPiker wrote in post #9894777 (external link)
"Probably soon" = "maybe one day".
When and if you move to a different format, you'll have to re-evaluate your lens set anyway, and you may even choose to keep an APS-C body. You would certainly be able to recoup a large fraction of the purchase cost if you should choose to sell your EF-S lenses at that time.
Why deny yourself access to the lens that perfectly addresses your needs now because, one day, maybe, you'll change formats?
bluefox9er
Location: UK,don't move ehre,it rains a lot, it's incredibly violent and the women pee standing up..
Mar 29, 2010 18:11 |  #13
get both
http://www.flickr.com …s/sets/72157602​470636767/ (external link)
http://www.flickr.com …ctions/72157604​292148339/ (external link)
Canon EOS 1d mk III, Canon EOS 5d,Canon EOS 400d, 24-70 mm F2.8 L, ef 24-105 F4 L IS, ef 17-40 mm F4 L, 70-200 mm f2.8 IS L, 100-400 mm IS L, 50mmm f1.8, 85mmf1.8mm, ef 35 mm f1.4L, ef 135 mm f2 L,Canon Powershot G9, Epson p400-, hyperdrive space 120gb
deadpass
Mar 29, 2010 18:22 |  #14
Rarely do I find myself in a situation where the 1 stop of light difference matters. If I need light that bad I'll switch to a fast prime.
a camera
http://www.deadpass.co​m (external link)
Fodowsky
Mar 29, 2010 18:22 |  #15
I went thru a similar thing. I ended up with both. 24-105 is my outdoors lens and the 24-70 gets the indoor gigs.
I'm glad I have both.
Gear and Feedback
9,621 views & 0 likes for this thread, 47 members have posted to it.
Latest registered member is sinonaut
697 guests, 125 members online
