Already have 35L, 85 1.8 and 70-200 2.8 L...and of course a 1d mark III body.
i need a WA lens for landscape and sport(skiing) any sugestions?
17-40, 16-35 II or the super expensive 14L II?
freeheeler Member 35 posts Joined Sep 2008 More info | Mar 29, 2010 15:37 | #1 Already have 35L, 85 1.8 and 70-200 2.8 L...and of course a 1d mark III body.
Saint728 Goldmember 2,892 posts Likes: 1 Joined Jun 2009 Location: Honolulu Hawaii More info | Mar 29, 2010 16:57 | #2 The only one that would be wide angle on your 1.3 crop would be the 14mm f/2.8L II. It would be great for landscapes, but not sure how it would be for sports/skiing? Canon EOS 1Ds Mark III | 17-40mm f/4.0L | 70-200mm f/2.8L USM | 100mm f/2.8L IS Macro | 300mm f/4.0L IS
ahendarman Senior Member 851 posts Likes: 1 Joined Sep 2008 Location: SoCal More info | Mar 29, 2010 17:42 | #3 |
mitsu13gman Senior Member 265 posts Joined Oct 2008 Location: Portsmouth, NH More info | Mar 29, 2010 20:21 | #4 Saint728 wrote in post #9895291 The only one that would be wide angle on your 1.3 crop would be the 14mm f/2.8L II. It would be great for landscapes, but not sure how it would be for sports/skiing? Take Care, Cheers, Patrick Well, relative to how they look on a full-frame, sure. But the general definition is that anything wider than 35mm (effective) is wide, so all of these fall into an acceptable range. Mike - "EXIF stripping is bad, mmmkay?"
Mar 30, 2010 11:26 | #5 for what i've understand:
Canonswhitelensesrule Goldmember 3,648 posts Likes: 13 Joined Jan 2008 Location: Surrey, B.C. More info | Mar 30, 2010 18:39 | #6 YES!! Photographers do it in 1/1,000th of a second...but the memory lasts forever!
cristphoto Goldmember 1,052 posts Likes: 72 Joined Feb 2010 Location: Maryland More info | Mar 30, 2010 20:52 | #7 The 17-40 works well for landscapes on a 1D3. I use that combination when the 35L isn't wide enough. On a 1.3 body the 17-40 works out to be a 22-52 which should be fine under most conditions. 1DX MK II, 5D MKIV x2, 24L II, 35L II, 50L, 85LIS, 100LIS Macro, 135L, 16-35LIS, 24-105LIS II, 70-200LIS, 100-400LIS II
cristphoto Goldmember 1,052 posts Likes: 72 Joined Feb 2010 Location: Maryland More info | Mar 30, 2010 20:56 | #8 Canonswhitelensesrule wrote in post #9902740 YES!! ![]() Finally another member with a great response. The modification is sooo easy, I can't understand why people are so reluctant or "SCARED" to even consider this lens. What's the modification - mounting it on a 7D? 1DX MK II, 5D MKIV x2, 24L II, 35L II, 50L, 85LIS, 100LIS Macro, 135L, 16-35LIS, 24-105LIS II, 70-200LIS, 100-400LIS II
| Latest registered member is IoDaLi Photography 1738 guests, 151 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
