Thread started 29 Mar 2010 (Monday) 19:23
Focus issues! want to pull my hair out
jeljohns
Mar 29, 2010 19:23 |  #1
I cannot seem to get the hang of focus! Some of my pictures are sharp, but I am having a lot of trouble with moving subjects. They seem soft. A photo friend of mine said it was because my subjects were not in an acceptable range of focus. If this is true-how can I tell how far my subjects can be and still be sharp?
Next question is this-I normally have my Rebel XS set to center focus. When I go to take a picture the red dot glows and it beeps. Does this mean that the center of the picture is the only thing in focus all the time? If a subjects eye is off to the left, do I point the red dot to the left, then recenter? I've been doing this and it causes me to miss the shot a lot of time because then the subject moves. I feel like I am constantly recomposing.
Here is an example of a picture taken inside of a fairly still subject, Focus seems sharp to me (on the nose/carpet).
Here is an example of the "soft" focus I'm getting outside when subjects are either farther away or moving. Both were shot with Tamron 28-75. Original as shot. I'm not sure how to get these shots sharp, on the eyes.
JoYork
Mar 29, 2010 21:12 |  #2
Conditions in the first pic look quite challenging, as there's not a huge amount of light available for the camera to focus in. Also, your camera has probably chosen a fairly wide aperture to let more light in which means the depth of field (ie the area that's considered to be sharp and in focus) is quite small.
In the first photo, the dog's nose looks to be sharp but not the eyes - so you can see the depth of field is quite narrow. Now, if you wanted to make sure the eyes are in focus you would aim at the eyes, wait for the red dot and beep, and then click. But you're wanting to re-compose which makes things harder.
First of all, recomposing will change the focus plane. Imagine you hold your arm outstretched so it's parallel to the ground, palm forwards as if you're touching a wall. Now if you move your arm up or down it's no longer touching the wall, right? That's similar to what happens when you recompose - the focus plane is moving, and the eye is not the same distance away as the nose so you get the wrong bit in focus.
There are several ways around this... all of them a compromise to some extent.
1) Choose a composition where the eye is in the centre. Or at least near enough. For this shot (external link) I moved so I was above the dog and aimed between her eyes. I then cleaned up the composition by cropping all the wasted space around her.Here's a shot (external link) of the same dog from a different angle.
2) You could use an external flash to provide more light, which will allow you to stop your aperture down which will give you more depth of field (more areas of the photo in apparent focus). This way you don't need to be quite as accurate - you'd get more depth of field at f/6.3 than you would at f/3.5 for example.
3) You can select a different focus point on your camera. Your success with this will depend on various factors; for example, on Rebel cameras only the centre focus point is a cross-focus point, meaning it's more accurate and has a better chance of locking on focus. Using the outer points tends to be slightly less accurate and works best with more light as well as a more contrasty subject area. Also, the focus points may not be in a very useful position for the shot, and by the time you've messed around the dog has moved.
4) Focus and recompose, then compensate slightly. This takes practice and is often hit or miss, but sometimes you can focus and get an idea about how much you need to move the camera forward or back to compensate for the focal plane moving.
Photographing animals can be a very frustrating experience... but we live in an age where the cost of taking a photograph is almost nil, and your patience will eventually pay off. I tend to work on the principle that 1 in 20 photos will be good enough that I'd want to show someone or print them out, so take a hundred and you might get 5-10 decent in-focus shots where the animal's looking in the right direction, not blinking, etc.
The second shot you posted isn't too bad. I guess it depends on your tolerance for how sharp the eyes have to be. I'd be quite happy with it, anyway. When a dog's walking towards you it will have moved a few inches between you focusing and then pressing the shutter button. You could increase the f/stop, as mentioned earlier, or try out the AI Servo mode on your camera. Some of them are bound to be keepers.
Good luck!
Jo
Invertalon
Mar 31, 2010 11:34 |  #3
You are in servo, correct?
-Steve
Facebook (external link)
yogestee
Mar 31, 2010 11:41 as a reply to  @ Invertalon's post |  #4
To me, the shot of the beagle looks sharp..
Jurgen
WAD
Mar 31, 2010 12:58 |  #5
Thanks JoYork for the valuable information.. I hadn't thought about the focus plane when recomposing from the half-click button press. I'll have to be more careful!
752 views & 0 likes for this thread, 5 members have posted to it.
2845 guests, 155 members online
