Overread wrote in post #9898646
I gots a new toy - and in the time honoured fashion of short, quickstart sheets its not told me quite how to use it....
I have a Powerrex MH-C9000 (also goes by the Maha brand name) and some
Energizer Rechargable 2500mAh
NH15 AA
1.2V NiMH HR6
In sets of 4 (set purchased as a single pack and kept with same 4 batteries all the time when cycling through the flash)
Those are all the details on the battery and because of their recent and past performance as well as history the "Refresh Analyze" (yes with a Z apparently...) mode is the one best suited to start trying to get some new life out of them. However the manual states that I have to enter the Charge and Discharge rate - however I am confused as to how I go about selecting the correct rates for each of these values.
Ok, well I have the same readings on my Energizer batts. I'm not sure if this is the answer your looking for but I've been through 4 sets of these batteries over time and I usually throw them away when they get about 50% of their original charged value (ex. if the batt originally shot 100 pics fully charged, when I can only shoot 50-60 pics with the same battery I throw them away)... here's the deal:
I have the Battery Grip for my 7D, I use the energizers 2500mah in it when I run out of actual Canon camera batts (4 in total), believe me not that hard to do when camping for the weekend. I usually carry 18 additional energizer batts (I number them to keep track of them with marker and use 1-6 all together, 7-12, and 13-18 all in the same way). A set will usually last me about 600-800 shots (or 1.5-2.5 hours of video shooting) depending on the usage but usually on the lower end of the scale. The batteries will last me to 50% capacity and go through 50-100 recharges before that time. The recharge time on 4 batts is approximately 3 hours.
I hope at least some of these numbers you can use.
