Thread started 30 Mar 2010 (Tuesday) 10:16
Flash Question
sboy
Mar 30, 2010 10:16 |  #1
hi guys. i have tried to play with my 580EX II and set my 7D to the wireless function that the flash gun will only work. however after several attempts, i have noticed that the built-in flash still fires when i took the shots. is there any problem with my camera or just the settings? i followed the settings in the manual. thanks in advance.
sixsixfour
Mar 30, 2010 10:27 |  #2
the built in flash will still fire because the signal emitted by the camera is (iirc) sent along as the flash fires. you cannot wirelessly trigger other Canon flashes without the built in flash firing.
oh and btw, wrong section ;)
Canon 7D / 50D / 30D / SL1 / XT
My photography-related addiction makes a crack habit look like a fiscally responsible pasttime.
sboy
Mar 30, 2010 10:30 |  #3
thanks sixsixfour.
sorry, dont know where to post my question.
sixsixfour
Mar 30, 2010 10:31 |  #4
no worries.
the flash section is here:
https://photography-on-the.net/forum/forumdis​play.php?f=35
have fun with the 7D + 580EX combo. I have that same setup too and love it. :D
rudy_216
Mar 30, 2010 19:54 |  #5
If for some reason you don't want the 7D's flash light in the scene (don't want a highlight reflection) then you can set your shutter speed above the normal X-sync speed and use High Speed Sync. This causes the master (your 7D in this case) to send the Fire flash signal before the shutter opens.
But under normal conditions the master fire flash command doesn't add a lot to the exposure.
750 views & 0 likes for this thread, 3 members have posted to it.
Flash Question
1037 guests, 164 members online
