Thread started 31 Mar 2010 (Wednesday) 01:29
New to PW Mini TT1 & Flex TT5
canondslr
Mar 31, 2010 01:29 |  #1
Hi Guys,
Im new to these OCF stuff, and new also to PW TT1 & TT5 devices.
So, I have some questions regarding those PWs, for now this one:
1.When I plug/unplug them from my computer for maintenance, do I just unplug it when Im done or do I have to do something like when we unplug an external HD (there's step to unplug it-> usb icon-> remove drive X-> safe to remove hardware-> unplug) ?
Thanks Guys...
Xang
1 post
Mar 31, 2010 02:02 |  #2
I always just pull mine out and they're fine...
ntc3
Mar 31, 2010 02:05 |  #3
I exit the PocketWizard Utility and then unplug them. Havent had any problems. But I wonder if there is an official method?
markhyo
Mar 31, 2010 02:22 as a reply to  @ ntc3's post |  #4
According to PocketWizards on their website, you can just pull the cord out and you do not need to exit the utility before doing so. You can also plug them in with the units on or off. If you have them turn on when you plug them in and then start the utility, the battery life will be displayed.
Mark W EOS 70D, 60D, Canon 18-55 f/3.5-5.6 IS STM, Canon 40mm f/2.8, 100mm f/2.8 Macro, Sigma 8mm Fisheye, Pentax 55mm f/1.8 M42 (For Sale)
http://www.markwphoto.​com (external link)
http://www.flickr.com/​photos/markwphoto/ (external link)
Check out our YouTube videos @ http://www.youtube.com​/user/markhyo?feature=​guide (external link)
canondslr
Mar 31, 2010 03:28 |  #5
Thanks for the responds Guys.
I have 2 Flexs and 1 Mini, so to close the program before changing to another Flex or Mini is just a hassle, glad we dont have to do that.
markhyo:
where did you got the info ? i went to their website and didnt find it (im new to their website too).
and I cant get the battery level displayed.
canondslr
Mar 31, 2010 04:15 |  #6
another question:
2.when using Mini or Flex to trigger Plus II, what chanel we use on the Mini/Flex and what channel on the Plus II ?
markhyo
Mar 31, 2010 07:59 |  #7
canondslr wrote in post #9905071 (external link)
markhyo:
I found this on the tutorial page. In fact in order to replicate settings from one radio to another you have to leave the utility running and change to the next radio in order to program it. Take a look at this link.
http://www.pocketwizar​d.com …als/pocketwizar​d_utility/ (external link)
You can also read about the utility at Rob Galbraith's website at the bottom of the page on tips. http://www.robgalbrait​h.com …page.asp?cid=7-9991-10030 (external link)
As far as getting the battery meter to show you must have the PW turned on before you plug in the usb. If you turn it on after the usb is plugged in it won't work. If you're having trouble disconnect everything, shut the pw off a few second, turn it on for a few seconds and try it again.
canondslr
Mar 31, 2010 10:37 |  #8
Hi Mark,
Thanks, I think I'll try again tonight.
And how about my question #2 ? I think I cant find te answer on the manual.
kwg105
Mar 31, 2010 11:21 |  #9
How does setting ratios work with the pocket wizards? If I have a 580exii and a 430exii, how can I adjust the ratio?
I normally do that on the camera. But, the manual for 5.0 firmware says that in camera controls don't work on the 7D. Is that a a temporary situation? Or just a product of the PW solution?
canondslr
Mar 31, 2010 11:28 |  #10
kwg105:
Im sorry, Im not even there yet :)
markhyo
Mar 31, 2010 11:30 |  #11
canondslr wrote in post #9906660 (external link)
Hi Mark,
I believe the Pocket Plus 2 work on standard channels 1-4. Should be on page 22 in the user manual.
markhyo
Mar 31, 2010 11:39 |  #12
kwg105 wrote in post #9906953 (external link)
Mount the 580EXII on the tt1. Hold down the zoom button and rotate the will to turn on wireless master mode. Press set to lock it in. Then press the zoom button until ratio flashes. Rotate the wheel to turn it on and press set. You have options for group A:B or A:B:C. Once it's locked on. Press the set button until ratio flashes. Rotate the wheel to set your ratio level. The 580EXII will on the camera will always be in group A! If you don't want the on camera flash to fire press the zoom button multiple times until the icon of the flash starts blinking. This will disable the 580 from contributing to the exposure.
I don't know if PW will ever allow control through the camera menu but the Zone Controller should help out big time once it's release. At that point a 580 probably won't even be needed! I'm even considering selling mine once the zone controller is released.
kwg105
Mar 31, 2010 14:09 |  #13
markhyo wrote in post #9907073 (external link)
Stupid question. But, looking at the Zone Controller.... I wouldn't be able to do your initial idea. (Of having the 580exii on the camera). Looks like there is no hotshoe on the top of the zone controller like there is in the mini.
markhyo
Mar 31, 2010 14:13 |  #14
kwg105 wrote in post #9908063 (external link)
The Zone controller replaces the 580EX. Basically it would sit on top of the TT1 and control group A, B, or C. You will be able to control the different zone by ettl or manually. The 580 could be used as an extra flash on a TT5 or in my case would probably sit in my camera bag most of the time. :)
canondslr
Apr 05, 2010 16:49 |  #15
Another question is how are you Guys bring it in the bag ? Lets say if you have 2 Mini's and 3 Flexes. I thought about those fishing tackle box with adjustable compartment ?
5,313 views & 0 likes for this thread
Latest registered member is JuliusFilip
741 guests, 343 members online
