Thread started 31 Mar 2010 (Wednesday) 04:47
batch change capture date & time
hania
Mar 31, 2010 04:47 |  #1
I got a new 7D to take to new zealand along with my 5D.
I forgot to set the camera time to be the same as on the 5D - so now I have photos taken from 1/3/10 (5d) and 1/7/10 (7d).
I have searched here for answers and tried to change capture time in Lightroom as suggested, but despite me selecting a range of photos in filmstrip, it only changed the capture time in the 1st photo- I dont want to have to do this for about 3000 !
There has to be a way!
tzalman
Fatal attraction.
Mar 31, 2010 04:56 |  #2
ExifToolGUI
http://freeweb.siol.ne​t …foto/exif/exift​oolgui.htm (external link)
Elie / אלי
hania
Mar 31, 2010 05:54 |  #3
many thanks - shall try this
obkcaptain
Mar 31, 2010 06:18 |  #4
hania wrote in post #9905245 (external link)
Doing it in Lightroom (2.5) is simply: mark all of them, entry into "Metadata" and set the offset + or - hours you want.
A Canon gear, some lenses, mono(tri)pod, flash and need to learn...
PixelMagic
Mar 31, 2010 07:11 |  #5
You need to select the photos you want to change in Grid view, not the filmstrip.
Also, for the changes to be made permanent, you will also need to press the CTRL+S keystroke command to "Write metadata to file."
MrWilliams
Mar 31, 2010 08:39 |  #6
So can I do this in grid view prior to import and have them imported with the correct date?
thanks
hania
Mar 31, 2010 10:01 |  #7
PixelMagic wrote in post #9905631 (external link)
Brilliant - worked fine - many thanks
3,922 views & 0 likes for this thread
Latest registered member is voidholder
1020 guests, 346 members online
