Is there any advantage in using either Faithful of Neutral cheers...Ray
grandadraymond Goldmember 1,946 posts Likes: 1 Joined Apr 2006 Location: Lancashire UK More info | Apr 01, 2010 13:05 | #1 Is there any advantage in using either Faithful of Neutral cheers...Ray
egordon99 Cream of the Crop 10,247 posts Likes: 3 Joined Feb 2008 Location: Philly 'burbs More info | Apr 01, 2010 13:41 | #2 Nope, because I shoot raw
gonzogolf dumb remark memorialized More info | Apr 01, 2010 13:45 | #3 Any of the picture style setting sare going to have some effect on your .jpg conversion. Generally the neutral of faithful do less in terms of altering the raw data as it comes from the sensor. This is likely to result in less vibrant and softer looking images as they apply less sharpening and saturation than some of the other styles. But like egordon says above. You can save yourself the bother and shoot raw so you get even better control of the conversion to .jpg.
With your gear, I'm going to assume that you, as you should, shoot in RAW and leave any PP to software, not in camera. The things you do for yourself die with you, the things you do for others live forever.
TeeWhy "Monkey's uncle" 10,596 posts Likes: 5 Joined Feb 2006 Location: Pasadena, CA More info | Apr 01, 2010 15:47 | #5 IIRC, neutral does not add any adjustments and Faithful is the same except the color temp is 5200K. Gallery: http://tomyi.smugmug.com/
| Latest registered member was a spammer, and banned as such! 2845 guests, 155 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
