Thread started 01 Apr 2010 (Thursday) 23:05
Canon recommend using a UV/protection filter on their lens
Bear ­ Dale
"I get 'em pregnant"
Apr 01, 2010 23:05 |  #1
I know that it's a divided world with the use of or non use of filters for "protection" but it was interesting to read that Canon recommend using a UV/protection filter on their lens
Cheers,
Bear Dale
Some of my photos featured on Flickr Bear Dale (external link)
blackhawk
Apr 01, 2010 23:11 |  #2
You prolly don't want to suck in water, and dirt with a lense that is front vented...
You got to know when to hold 'em, know when to fold 'em
Know when to walk away and know when to run
You never count your money when you're sittin' at the table
There'll be time enough for countin' when the dealing's done
Bear ­ Dale
Apr 01, 2010 23:28 |  #3
Wouldn't it still have to suck past the filter thread though?
Cheers,
Bear Dale
ben_r_
-POTN's Three legged Support-
Apr 01, 2010 23:29 |  #4
Just out of curiosity, where exactly did you see that Canon said this?
Vladimer
Apr 01, 2010 23:40 |  #5
blackhawk wrote in post #9917508 (external link)
OT a little. I thought the L series is suppose to be more weather resistant then the rest of the canon line up.. so... whats with the holes? :confused: never knew they vented the lenses
blackhawk
Apr 01, 2010 23:51 |  #6
Vladimer wrote in post #9917653 (external link)
The 16-35L is front vented. A filter completes it's weather sealing.
Vladimer
Apr 02, 2010 00:28 as a reply to  @ blackhawk's post |  #7
Gotcha, Thanks for the heads up.
hollis_f
Apr 02, 2010 06:22 |  #8
fotoworx wrote in post #9917484 (external link)
Well, that's a good example of how to take part of the information and use it to spread misinformation. Canon recommend using such a filter on some lenses, only to complete the weather protection. So that recommendation is only applicable if you're using one of those lenses on a weatherproofed camera.
Here's what Chuck Westfall, from Canon, says about filters -
If I knew I was going to be exposing the 16-35mm lens to a hostile environment such as rain, sea spray, car exhaust fumes, etc., I would use a good quality clear or UV filter to protect the front element. I would also consider using a thin-rim circular polarizing filter to cut glare, etc., if the shooting conditions called for it. But in most other cases where the lens is in no imminent danger, I would remove all filters for maximum optical performance, and use the supplied Canon lens hood to reduce flare and help prevent impact damage.
Source (external link).
And here's what Erik Allin says -
ANY and ALL UV/protection filters have some degree of negative impact on image quality. Some more than others. With some extremely high-quality multi-coated UV filters – typically very expensive – the IQ impact is so negligible as to be unnoticeable in the finished printed image to most people. Most UV filters exhibit some IQ degradation that can be seen to some degree in the image. Some UV filters can be quite bad.
- Source (external link).
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
Bear ­ Dale
Apr 02, 2010 06:59 |  #9
hollis_f wrote in post #9918594 (external link)
Well the above is a a good example of YOU spreading misinformation.
Canon USA - Lens Protection/Lens Care 101
http://www.usa.canon.c​om …FLenses101/lens​_care.html (external link)
Consider using a Skylight or UV filter as full-time protection of your lens, shooting your pictures through it and removing it only when you're using another filter for special effect. And of course, don't forget to use your front and rear lens caps!
Cheers,
Bear Dale
rklepper
Dignity-Esteem-Compassion
Joined Dec 2003
Apr 02, 2010 07:28 |  #10
I am starting to think that this is a controversial topic.:)
Doc Klepper in the USA
I
blackhawk
Apr 02, 2010 07:43 |  #11
rklepper wrote in post #9918810 (external link)
Not really. Those who don't use filters shouldn't be surprised though when they see splintered sun because of marred front elements.
I have 4 damaged or destroyed filters, and not even the slightest bit of damage on any of my front lense elements.
Those filters would have been my front elements... filters are also much easier to clean.
SkipD
Joined Dec 2002
Apr 02, 2010 07:51 |  #12
Nahhh. What makes you think that? :rolleyes:
Skip Douglas
nightcat
Apr 02, 2010 07:59 |  #13
blackhawk wrote in post #9918872 (external link)
Well, I have no damaged filters because I don't use them, and I also have "not the slightest bit of damage on any of my front lens elements". I do however have several badly banged up lens hoods. Those hoods would have been my front elements if they weren't attached.
Wilt
Apr 02, 2010 09:07 |  #14
Democrat...Tea Party...Republican
Right wing...Moderates...Lef​t wing
Pro Life...Abortion rights
Marriage of gays...'Marriage' is btw. man and woman
Muslim...Christian
Death sentence...anti death sentence
Filters always...use em when you need to...filters never
blackhawk
Apr 02, 2010 09:24 |  #15
nightcat wrote in post #9918935 (external link)
Bet I could find marring on many of these "undamaged" lens I hear about that are cleaned at least once a week.
Funny, I use hoods all the time, and they don't look that bad. Not buying your story 100%...
It's very easy to mar even a hard surface and most common grit found on the floor/ground is hard enough to do this.
There are times when filters need to be removed, but never using them isn't a good solution for many who shoot outside.
No reason to cause needless wear and tear for minimum (or no) results, or to save a few dollars when you've invested thousands already.
3,438 views & 0 likes for this thread, 11 members have posted to it.
2633 guests, 157 members online
