Thread started 04 Apr 2010 (Sunday) 07:59
can you help with a battery grip
big-al1956
Apr 04, 2010 07:59 |  #1
hi i have just bought a bg-e3 battery grip for my 400d and i cant seem to get it to work can anyone help please
MARK1992
Apr 04, 2010 08:03 |  #2
A little more information would help heaps ;)
lannes
Apr 04, 2010 08:20 as a reply to  @ MARK1992's post |  #3
check you got it switched on, switch is on the side of the grip
big-al1956
Apr 04, 2010 08:56 |  #4
more information put battery into tray attached it to camera turned on switch on grip when i try to turn on the camera nothing happens the camera is dead have tried it with the aa battery tray as well and it is just the same if i put the battery back into the camera every thing works fine
duane0524
Apr 04, 2010 09:01 |  #5
big-al1956 wrote in post #9930028 (external link)
Here is a stupid question and I mean no offense, did you turn the grip on?
Canon 50D | Canon 17-55 | Sigma 30 1.4 | Canon 70-200 2.8 IS II| Canon 85 1.8 | 430EXII| 580EX ll | ST-E2 | Canon TC 1.4x II | Benro Travel Angel C1682TB0
big-al1956
Apr 04, 2010 09:04 as a reply to  @ duane0524's post |  #6
yes the grip was turned on and its not a silly question just glad of any held that will get it to work
duane0524
Apr 04, 2010 09:37 |  #7
big-al1956 wrote in post #9930059 (external link)
Actually I just remembered that it does not matter if the grip is on/off to turn on the camera.
Ok, I just check mine out and there are not lots of ways for this to go wrong.
The batteries are fully charged?
The gripped is screwed in all the way?
Battery door is closed all the way? Double check that as it may looked closed, but if it is not closed all the way you won't have contact.
lannes
Apr 04, 2010 10:46 as a reply to  @ duane0524's post |  #8
If you screw the grip in too tight it can cause connection problems, it should be just tight enough. Back off on the tension.
The contacts are spring loaded on top of the section you insert into the camera's battery compartment, check none are stuck down, give each one a bit of press/ jiggle to make sure they are fully extended.
big-al1956
Apr 04, 2010 11:44 as a reply to  @ lannes's post |  #9
could it be the battery as it says nb-2lh and mine are nb-l2 is there a differance
Jon
Joined Jun 2004
Apr 04, 2010 12:07 |  #10
NB2LH has a bit more capacity, but the two are freely interchangeable.
Jon
Cocker Spaniels
JWright
Joined Dec 2004
Apr 04, 2010 14:45 as a reply to  @ Jon's post |  #11
Canon BG-E3 or third-party?
John
big-al1956
Apr 04, 2010 16:17 as a reply to  @ JWright's post |  #12
it is a genuine canon bg-e3
LowriderS10
Apr 04, 2010 19:13 |  #13
clean all contacts? Did you remove all protective plastic, etc?
-=Facebook=- (external link)
-=Flickr=- (external link)
-=Gear=-
Jon
Joined Jun 2004
Apr 04, 2010 19:19 |  #14
There's a microswitch on the body that the battery compartment door closes - check to see if that's working properly. If it is, then check out the grip to see if it's going to be able to make contact with the switch.
Jon
Cocker Spaniels
LowriderS10
Apr 04, 2010 21:08 |  #15
Have you tried putting a different grip on it? Or putting your grip on somebody else's camera?
-=Gear=-
1,450 views & 0 likes for this thread, 8 members have posted to it.
2637 guests, 156 members online
