Thread started 04 Apr 2010 (Sunday) 15:40
Manfrotto CF Tripod -- 3 or 4 sections
brucea
Gallery: 28 photos
Joined Oct 2004
Apr 04, 2010 15:40 |  #1
Manfrotto makes two versions of their 055CXPRO tripod: 055CXPRO3 and 055CXPRO4
Aside from some slight size and weight differences (and price difference), why would one choose a 3 leg section tripod over a 4 leg section tripod, or vice versa?
ed ­ rader
"I am not the final word"
Apr 04, 2010 15:57 |  #2
brucea wrote in post #9931913 (external link)
three-section is stiffer, sometimes taller and quicker to set up.
ed rader
5D4 x2, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, 14L II, sigma 15 FE, sigma 28 f1.4 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
Tsmith
Formerly known as Bluedog_XT
Apr 04, 2010 16:05 |  #3
Myself I prefer the 3 leg section design for a slight better stability. Anytime you add another leg section its going to be smaller than in diameter giving up some stability. Generally though the 4 section ones are more compact allowing for easier transport.
Hi ed ... :cool:
ed ­ rader
Apr 04, 2010 17:05 |  #4
Tsmith wrote in post #9932009 (external link)
Hi ed ... :cool:
Toney -- always good to hear from you my friend :D.
ed rader
brucea
Gallery: 28 photos
Joined Oct 2004
Apr 05, 2010 13:47 |  #5
Thanks, makes sense, should have thought of it myself.
klr.b
Apr 05, 2010 16:39 |  #6
if you think you may ever want to pack it inside of a bag, you may want to look at the 4 section ones.
gordon
Gear and Feedback
argyle
Apr 05, 2010 17:03 as a reply to  @ klr.b's post |  #7
Depends on the tripod. Generally, the 3-section will provide more stability than a 4-section. That being said, on a good quality tripod, I doubt that you'll see the difference, much less be able to measure it, between the two styles. But again, that depends on the tripod. I use a 4-section Gitzo, mainly because I like the shorter folded length when strapping it to a backup. The bottom leg is still pretty stout (about 16mm OD)...I've had it in the surf off Hawaii, in rushing water, high winds, etc and have never had a problem with motion blur. On the other hand, I've seen some 4-section tripods where the last leg section was literally pencil-thin...made for a lot of "spring" and terrible support. As far as set-up time goes, the extra time due to the fourth leg section is pretty minimal (and a lot depends on the style of leg locks). But again, we're talking seconds, not minutes.
MrGreen
Apr 06, 2010 13:33 |  #8
argyle wrote in post #9938762 (external link)
Agreed. I have a 4 section tripod and never once have I wished I only had 3.
My site: www.millionflame.com (external link)
Gear: 7D - Zeikos Grip, Rebel XTi/400D - Opteka Grip, EF 24-105mm f/4L, EF 100mm f/2.8L MACRO, EF 50mm f/1.8 (Nifty Fifty), EF-s 55-250mm (Nifty Two-Fifty), Tokina 11-16mm f/2.8, Σ 150-500mm (Bigmos), Σ 35mm f/1.4, Σ 85mm f/1.4, Feisol CT-3442 CF Tripod, Photo Clam PC-40NS Ball head, 580 EX II Flash
hyt
Apr 07, 2010 19:43 |  #9
I used to own a Manfrotto 055MF3 (previous incarnation of the 055CXPRO3) and never found it to be exceptionally stable. The culprits seemed to be the "pro" feature which is basically a plastic (and therefore, flexible) clamp holding the center column, as well as the legs themselves. I'd venture a guess that the 4-section would probably be even worse.
4,034 views & 0 likes for this thread, 7 members have posted to it.
1387 guests, 135 members online
