Thread started 05 Apr 2010 (Monday) 08:22
Why can't my card reader read PQI cards?
g3org3y
Apr 05, 2010 08:22 |  #1
Bit of an odd one.
Ever since doing the firmware/hack upgrade on the CF cards for my 400D I've had to use the card reader (connection/hang up probs). Not an issue on my two 'hacked' Sandisk 4GB CF cards, on insertion they work perfectly. Using the PQI card (same hack applied in exactly the same way), no automatic recognition of it being in there and it says 'insert disk'.
I initially used a USB connected card reader to apply the hacks and it worked fine on all three cards however I don't have this to hand at the mo. As such have to use the inbuilt card reader in the Dell which is struggling with the above problem.
Tried upgrading the firmware (of the card reader) but to no avail.
All photos perfectly viewable on the camera itself.
Any ideas? TIA :)
EOS 400D, Sigma 10-20, Tamron 17 -50, Nifty Fifty f/1.8, Canon 100 f/2, 70-200L f/4, Speedlite 430EX II.
Jon
Joined Jun 2004
Apr 05, 2010 08:27 |  #2
Are all three cards formatted using the same file system? Partitioned the same? Just a thought.
Jon
Cocker Spaniels
g3org3y
Apr 05, 2010 08:38 |  #3
To my knowledge, all identical. The difficulty of course is in access - can't do it via the camera. Can't do it via the inbuilt card reader. May need to wait until I can get to my USB card reader (at least another week or two).
The worry is that it is full of snaps from my latest holiday in Morocco. Very fearful I will not be able to retrieve them. :(
Wilt
Apr 05, 2010 10:41 |  #4
You hacked the firmware of Sandisk cards. That does not mean that the same firmware update was necessarily compatible with your PQI cards, which it sounds as if you did this!
g3org3y
Apr 05, 2010 11:49 |  #5
Any cunning plans in that case?
619 views & 0 likes for this thread, 3 members have posted to it.
2637 guests, 156 members online
