Thread started 06 Apr 2010 (Tuesday) 01:42
5d2 in "M" Mode - Cannot adjust aperture
TexRex
Apr 06, 2010 01:42 |  #1
Hi all. I have a simple question that I cannot figure out. When shooting in "M" mode, The top dial by the shutter button controls my shutter speed and the main dial is supposed to control my aperture but I cannot get it to adjust aperture. The power switch is all the way up as it works on all the other menu functions etc so I know it works. Any help would be greatly appreciated.
Canon stuff....
malla1962
Joined Jul 2004
Apr 06, 2010 01:45 |  #2
Do you have the on switch all the way on? EDIT Yes you have,sory
TexRex
Apr 06, 2010 01:47 |  #3
malla1962 wrote in post #9941486 (external link)
Yes it is all the way on to the the top. Is there some type of menu option that needs to be adjusted to allow for aperture control with the main dial?
Canon stuff....
Maureen ­ Souza
Apr 06, 2010 01:53 |  #4
No. make sure the switch is all the way to the top...Aperture is controlled with the dial above the switch.
5DMK4
7DMK2
TexRex
Apr 06, 2010 01:59 |  #5
Maureen Souza wrote in post #9941514 (external link)
Yep. Its all the way to the top and in "M" mode the only way I can control apperture right now is to go into the menu and adjust the aperture by the main control dial above the switch so I know it works. nI just for some reason cannot control the aperture otherwise with the wheel like it should be.
Canon stuff....
gofer
Apr 06, 2010 02:01 as a reply to  @ TexRex's post |  #6
Have you re-assigned the rear dial to AF points?
Steve.
TexRex
Apr 06, 2010 02:06 |  #7
gofer wrote in post #9941532 (external link)
You mean "AF point selection method"?
Canon stuff....
malla1962
Joined Jul 2004
Apr 06, 2010 02:16 as a reply to  @ TexRex's post |  #8
Start by clearing all custom functions.
TexRex
Apr 06, 2010 02:18 |  #9
malla1962 wrote in post #9941561 (external link)
Just did, still no luck.
Canon stuff....
malla1962
Joined Jul 2004
Apr 06, 2010 02:39 as a reply to  @ TexRex's post |  #10
Not sure what to say then,Could be a trip to canon.
Lowner
"I'm the original idiot"
Apr 06, 2010 03:22 as a reply to  @ malla1962's post |  #11
Is this related to the latest firmware bug in M?
Follow the Canon Rumours link. It certainly seems similar to an outsider.
Richard
Nietzsche84
Apr 06, 2010 03:24 as a reply to  @ Lowner's post |  #12
sorry, that sounds like a trip to Canon. Or at least ring them up.
wem
Apr 06, 2010 03:28 |  #13
If you're sure about having cleared the custom functions and the switch, it sounds like it needs to be serviced ...
My gear list
My flickr (external link) page
wimvangestel.com (external link)
apersson850
Apr 06, 2010 03:54 as a reply to  @ wem's post |  #14
It could be the switch. You can use the rear wheel to move around in menus regardless of whether the ON/OFF switch is in the second or third position.
The AF control by the rear wheel is a typical issue. Did you clear all custom functions? Note that clearing the camera settings is not the same thing. Try by holding the AF selection button and spin the top wheel. If that controls the aperture, it's the AF direct selection that's the culprit.
In manual mode, you can on most cameras press the * button (there's no AE lock anyway) while turning the main wheel, and set the aperture that way.
Can you adjust EC in any automatic mode?
Anders
tdodd
Apr 06, 2010 05:40 |  #15
I've seen this complaint with a 40D before. It turned out the power switch was not working properly and the "fully on" position was not being recognised. Try operating the power switch a few times to clean the switch contacts inside.
2,194 views & 0 likes for this thread
Latest registered member is reservengineer
968 guests, 354 members online
