Thread started 07 Apr 2010 (Wednesday) 08:39
Remote 580EXII with 420EX Delay
PhotoCarp
Apr 07, 2010 08:39 |  #1
Hi, first time poster here. Feel free to send me packing if this is not the place to ask this.
I wanted to try a different setup today. A PocketWizard PlusII on a 5D MkII firing a PocketWizard PlusII connected to 580EXII as the master, a 420EX as the slave. The 580 fires without any problem but the 420 fires after a brief delay(maybe a half second). If I mount the 580 in the shoe then the 420 fires simultaneously. Now I suppose I could achieve a really cool effect with a long enough exposure but that's not what I want. I would like to have both flashes fire simultaneously with neither one mounted on the shoe.
Am I doing something wrong? Is there a way to do this without having to use something other than the PocketWizards?
I tried using different settings but the 580 will act as a master only when it is in ETTL mode so Manual and Multi mode will not fire the 420.
Big ­ G
Apr 07, 2010 08:56 |  #2
Welcome to POTN.
I think this was a similar issue to yours. Click here for another thread on POTN
S100, 1000D (My first DSLR) plus 5D and various lenses
Full Gear List
Austin.Manny
Apr 07, 2010 09:53 |  #3
You need another PocketWizard.
450D Gripped | Σ 30 f/1.4 | 85 f/1.8 | 18-55 IS
LumoPro LP180 | Yongnuo YN-460 |
RF-602
PhotoCarp
Apr 10, 2010 08:35 |  #4
BigG,
Thanks for the link. That pretty much answers my question. A lot of additional info in there as well.
Austin.Manny,
That would do it but I would also need something like this (external link)
PacAce
Joined Feb 2003
Apr 10, 2010 11:28 |  #5
PhotoCarp wrote in post #9949335 (external link)
You're problem is the fact that the 420EX only works in E-TTL mode and does not have a manual flash feature so there is no way you'll be able to trigger the 420EX with a 580EX as a master triggered by a PW Plus II. For this "hybrid" triggering to work, all the flashes need to be in manual mode and the 420EX can't meet that requirement.
You can use a separate PW unit to trigger the 420EX but it'll fire at full power all the time, again, because it can't be controlled manually. And E-TTL does not work with any RF remote system unless the system supports E-TTL operation, like the PW MiniTT1 and FlexTT5.
...Leo
1,346 views & 0 likes for this thread
Latest registered member is stitch123
1060 guests, 346 members online
