Thread started 07 Apr 2010 (Wednesday) 14:42
How to micro adjust??????
jayseersts
Apr 07, 2010 14:42 |  #1
Hey fellow potn members. I just want to know if anyone here can give me links on how to micro adjust my lenses on a 7d. I do have the "focus genie" but i do wanna know how to use it properly. Thanks in advance!
CANON 5D MARK II GRIPPED/35 1.4 L/2X AB800/CYBERSYNCS
james_in_baltimore
Apr 07, 2010 14:59 |  #2
I'm sure if you search this forum for microadjust you will find a bunch of links. There are several different methods with everything from using special focus charts to moire patterns on your monitor. Canon recommends testing with a subject distance no less than 50X your focal length. Also, for zooms they recommend using the longest fl.
here is one website some people use and it also describes some of the other methods out there.
http://www.northlight-images.co.uk …s3_af_micoadjus​tment.html (external link)
James Harris Photography - Weddings Portraits Events (external link)
Canon 7D, 5D Mkii, 580EX II X2, 430EX, ST-E2
24-70mm f/2.8L, 70-200mm f/2.8L IS ii, 17-40mm f/4L, 50mm f/1.4
K_AMJ
Apr 08, 2010 01:24 as a reply to  @ james_in_baltimore's post |  #3
There are so many threads and links explaining the issue, but let my give you my experiment with a 70-200 2.8 IS on 5D mkII which should be basically the same in a 7D.
Installing the camera on a tripod (about 0.5m height), setting the focus on SPOT, setting the camera on MLU and 2s timer, f2.8 (for getting narrowest DoF), setting longest focal length on the lens, I put an A4 text in a distance of about 2.5m apart on floor.(text should be single font size printed to give you an scale abut focus deviation)
Aiming on specific line in the text I took first shot; then going to micro adjustment menu in the camera, I took next shots with different "+" and "-" adjustments. (making a list of adjustments vs. file number will help you later to apply final adjustment). I transferred taken shots to PC and observed the results at 100%. Next step will be applying the micro adjustment value corresponding to shot with most precise capture of the aimed line in the text.
I'm totally happy with result, I took these shots right after adjustment in different f numbers:
f8: http://www.pbase.com/k​_amj/image/110326510 (external link)
f5.6: http://www.pbase.com/k​_amj/image/110361850 (external link)
f3.2: http://www.pbase.com/k​_amj/image/110216423 (external link)
f2.8: http://www.pbase.com/k​_amj/image/110213381 (external link)
EOS 20D
EF-S 17-85
EF 50 f1.8
EF 70-200 IS
Sigma 70-300 APO
Sigma 2X EX APO DG
Sigma EF-500 super E-TTL II
Gallery:
WWW.PBASE.COM/K_AMJ (external link)
mike ­ cabilangan
Apr 08, 2010 01:47 |  #4
a related question:
what are the chances my lenses need micro adjust?
camera bag reviews (external link)
flickr (external link)gearLust
jayseersts
Apr 08, 2010 02:07 as a reply to  @ mike cabilangan's post |  #5
james_in_baltimore wrote in post #9951616 (external link)
hey thanks for the link, i'm actually using the focus genie atm...but the link was very helpful
K_AMJ wrote in post #9954854 (external link)
thanks, very helpful
OregonRebel
Apr 08, 2010 02:31 |  #6
mike cabilangan wrote in post #9954913 (external link)
a related question:
If any are made by Sigma, pretty good.
Brian N
7D, Rebel XT, G16, EF-S 10-22, EF-S 15-85 USM IS, Sigma 30 f/1.4, EF-S 60 macro, 85 f/1.8, EF 70-200 f/4L IS , Canon 1.4 TC, 430 EX, 270 EX
Bogen/Manfrotto 3001BPro/484RC2
Some pix at www.flickr.com/photos/​briann/ (external link)
newworld666
Apr 08, 2010 03:13 |  #7
I Have a 24L1.2II, 24F1.8 Sigma, 50F1.4, 85L1.2II, 135L2.0, 300L2.8nonIS and 70-300DOIS TC2X TC1.4X
Only 85L1.2II doesn't need to be micro adjust with 5DMKII ......
For other lenses it's from -5 till +17 (with stacked TC2X+TC1.4X)
I used many way to do it .. and it's quite tricky
http://photo.net/learn​/focustest/ (external link)
http://www.komar.org/f​aq/camera/auto-focus-test/ (external link)
http://www.slrgear.com​/articles/focus/focus.​htm (external link)
I could do perfect micro-adjustments with this tecknics ..
But since I bought lensalign I could confirm results, but new lenses are taking a few minutes to do it...
http://www.lensalign.c​om/ (external link) expesive but a real pleasure to do it.
I would say, that I don't understand how we can use a lens AF without doing any micro adjustment .. sharpness is so different due to front or back focusing... Don't buy any body that can't be adjusted by lenses unless you correct manually any AF!!!
Marc
5DMKII+1Dx 24L1.4II 85L1.2II 180L3.5 300F2.8nonIS TC2XII ..... Sigma14F2.8AFDG, Zuiko 500F/8 Reflex
http://myc-photos.eu (external link)
denoir
Apr 08, 2010 03:40 |  #8
a related question:
Very good. I think there was one lens in my lineup that didn't require MF adjustments - on my 7D. On the 5D2 every single one required a pretty strong adjustment (i.e. bad sensor distance alignment).
I see now with hindsight that what I attributed to bad quality glass on my older camera houses was probably just a question of AF adjustment. Canon quality control is unfortunately abysmal and not even their most expensive glass is consistently well adjusted.
Luka C.D| My photos (external link) | My videos (external link) | My Cameras & Lenses
KRUSH
Apr 08, 2010 03:59 as a reply to  @ denoir's post |  #9
How do you know IF your lens needs to be Micro Adjusted?
The presence of the observer changes the nature of the observed...
Canon EOS 5D Mk II | Gear List & Feedback
For Sale: Canon S5 IS |
newworld666
Apr 08, 2010 04:06 |  #10
KRUSH wrote in post #9955235 (external link)
It's very easy, when you get sharper images with lifeview than with AF ... then you can with DPP by puting sharpness to maximum you can easily see if you have a front focus or a back focus...
Marc
FlyingPhotog
Cream of the "Prop"
Apr 08, 2010 04:06 |  #11
You will see a consistent pattern where sharp focus falls either slightly behind (back focus) or slightly in front of (front focus) where the actual selected focus point falls in the frame.
There are variables of course that can make AF less effective:
- Lack of Contrast (Grey Wolf in the fog)
- Allowing the camera to choose the AF point (do it yourself!)
- "Focus and Recompose" when shooting wide open at extremely shallow DOF
Jay
hqqns
When the frick did I get this new title and why?
Gallery: 29 photos
Apr 08, 2010 04:18 |  #12
I have a questions to do with microadjustment
The microadjustment that is made seems to have no units associated with the numbers so unless you have a camera with that abilty, you don't know how bad for example +17 is. I'd like to see some examples of images of an object taken before and after microadjustment. Or is someone able here to quantify these values.
Thanks Subby
subby
Proud owner of a late ADHD diagnosis.... at age 47, whoop. Meds are a game changer: first time in my life I love my work...crazy
"I am 48"
FlyingPhotog
Cream of the "Prop"
Apr 08, 2010 04:22 |  #13
hqqns wrote in post #9955268 (external link)
Thanks Subby
I don't believe this would really be meaningful.
Because of manufacturing tolerances, my zero point will be slightly different than your zero point so my +5 won't automatically be +5 for you.
And remember too, you have tolerances for both the body and the lens so it's a "double floating zero point" as it were.
ETA: If you go out expecting to find flaws, you'll find flaws. FWIW, Across four bodies and 14 lenses since I first used a dSLR, I've never seen any iffy results that I could ever nail down as being exclusively hardware induced.
Digging into my own EXIF, I'll find shutter speeds that maybe were a hair too slow for optimal imaging as well as instances where I was on the ragged edge of MFD (minimum focusing distance) or shooting so wide open that a wobble by me or by my subject meant an OOF image (often all it takes is I lean in slightly while he/she does the same and OOF is the result.)
Jay
hqqns
Gallery: 29 photos
Apr 08, 2010 04:44 |  #14
FlyingPhotog wrote in post #9955283 (external link)
Understood. So what you are saying i think is that the tolerances of both the body and lens have a factor. But that tolerance even if floating will have a definate distance between specific body and specific lens.
In a perfect world the distance from "sensor to mount" and "lens optics to mount" will be exact and exactly in focus. These distances can both change so it makes sense to have microadjustment to correct for real world differences from the ideal.
So my question still is ignoring any zero points what does it mean to got+- a step. Does that make sense ?
subby
"I am 48"
FlyingPhotog
Cream of the "Prop"
Apr 08, 2010 04:46 |  #15
hqqns wrote in post #9955327 (external link)
I see what you're getting at...
I can't say I've ever seen anyone quantify a measure for what each "tick" plus or minus equals. "Focus Charts" are generally in mm's but whether or not each tick means one mm of change...?
Jay
10,028 views & 0 likes for this thread, 12 members have posted to it.
Latest registered member is j73m10r
709 guests, 193 members online
