Thread started 08 Apr 2010 (Thursday) 17:36
Most Reliable external HD?
Coppatop85
Apr 08, 2010 17:36 |  #1
I am looking to pick up a 1TB external HD to back up all my photos (and some other media). I have heard a few horror stories about external HD's failing, which I would hate to have happen.
Can anyone recommend me a reliable brand of external hard drive? Thanks!
5D3, lenses, tripod, and a flash.
Wobsite: www.coppatopphotos.com (external link)
SYS
Gallery: 602 photos
Joined Jul 2004
Apr 08, 2010 17:41 |  #2
TWO of any top brands, i.e., there's no single most reliable brand, so as far as I'm concerned having a duplicate HD is the way to go.
-Goethe
robscomputer
Apr 08, 2010 17:45 as a reply to  @ SYS's post |  #3
I really like Western Digital, used them for the past 10 years and been very good. But I also backup my data and use Mozy.
Amateur photographer
RDKirk
Adorama says I'm "packed."
Joined May 2004
Apr 08, 2010 17:49 |  #4
Coppatop85 wrote in post #9959082 (external link)
More important than the brand of drive is the type of enclosure. Heat is the greatest enemy and the greatest failing of many enclosures--an enclosure that forces a drive to run hot will kill any brand quickly.
I prefer enclosures that are designed to have very large air spaces around the drive body that are designed for effective convection cooling--the Western Digital "book" enclosures are like that (and Western Digital is probably the best consumer drive you can get right now).
Second, imo, are fan-cooled enclosures, but they have the problem of noise and the possibility of failure--once the fan fails, the drive will overheat and fail quickly.
The worst enclosures are those that depend on conducting heat from the drive through a smooth-bodied metal enclosure.
LowriderS10
Apr 08, 2010 17:58 |  #5
Tons of threads about this...but, I've had a Western Digital for about 3 years and it's been flawless
-=Facebook=- (external link)
-=Flickr=- (external link)
-=Gear=-
CafeRacer808
Apr 08, 2010 18:01 |  #6
I've had really good luck (knocking on wood as I type this) with both Western Digital and LaCie drives.
Dave d-.-b
5Dii | 50D | 24L | 35L | 50/1.4 | 85/1.8 | 100L Macro | 17-50/2.8 | 28-105/3.5-4.5 | 70-200/2.8L | 580EX II
Mystwalker
Apr 08, 2010 18:05 |  #7
Have been using Seagate FreeAgent USB drives for years - no problems yet, but then I only use them to back up photos. Have 160GB, 500GB, 1TB and 1.5TB - something like that. I do not keep them on all the time.
Recently got a WD 1.5TB which have worked well, but it's only been couple months.
keitaro
Apr 08, 2010 18:17 |  #8
These are the brand that I hear are one of the most reliable solutions for an external hard drive
http://www.lacie.com/c​a/index.htm (external link)
http://www.g-technology.com/ (external link)
http://www.wdc.com/en/ (external link)
http://www.seagate.com​/www/en-us/ (external link)
If you have a grand to spend, you could get a Drobo unit, and max it out with hard drives. It lets your run standard hard drives, up to 10+ TB of data. http://www.drobo.com/r​esources/vm_photograph​y.php (external link)
My flickr (external link)
xcel730
Apr 08, 2010 18:23 as a reply to  @ Mystwalker's post |  #9
Have you considered getting a NAS? (Network Attached Storage). If you get one with two bays, you could set it up with RAID, which is great for redundancy. The pro is if any one of the hard drive dies, you could still recover you data. The con is that your two drives essentially becomes one (since one is your real data and the other is a mirror copy). An added benefit of NAS drives is that it is connected to the internet, so you can upload your photos when you're away.
________
[Gear List]
Quote: If the grass is always greener on the other side, then maybe you should start working on your own grass.
rklepper
Dignity-Esteem-Compassion
Joined Dec 2003
Apr 08, 2010 19:00 |  #10
I would buy an enterprise level drive and put it in your own enclosure. Manufacturers do not put the best drives in their externals.
Doc Klepper in the USA
I
hyt
Apr 08, 2010 21:01 |  #11
I have:
Western Digital Scorpio Blue 500 GB Bulk/OEM Hard Drive 2.5 Inch, 8 MB Cache, 5400 RPM SATA II WD5000BEVT
enclosed in a
Acomdata Tango 2.5-Inch USB 2.0 eSATA Portable Enclosure for SATA Hard Drive TNGXXXUSE-BLK (Black)
Easy installation, all metal enclosure that conducts heat away from the drive. Small enough to fit in my shirt pocket. All my stuff is backed up on it monthly, and the drive is stored in a physically separate location from my residence.
Todd ­ Lambert
I don't like titles
Apr 08, 2010 21:04 |  #12
Almost all drives are about the same nowadays. Each mfg has issues with their drives and reliability is not something that can be accounted for anymore, unfortunately.
Generally, the larger the drive, the more possibilities of having issues, and also losing the most data, obviously.
As has been suggested, RAID is the way to go, along with off-site back up in addition to that.
smcclelland
Apr 08, 2010 21:41 |  #13
bannedPermanently
Like others I have a bunch of enclosures and "safety nets". I use a WD Studio 1TB alongside my 1TB Time Capsule that has another 1TB hanging off of it. I've been lingering on ordering a Drobo or a DroboPro (video work sucks too many gigs of space doing post effects) but am waiting for a nice price point on the Drobo FS or DroboPro.
I also backup all my stuff off-site and have an external drive at my office as well.
Shawn | Flickr (external link) | Blog (external link)
There used to be Canon gear here but it disappeared.
C_Riv
Apr 08, 2010 22:52 |  #14
I'm a fan of the Lacies. FW 800, and made of aluminum so they dissipate heat. I've been looking at the Drobos but they are expensive.
http://www.darrinriver​.com (external link) - My Website - http://www.indiadarrin​.blogspot.com (external link) - My photo blog while in India! - Gear List
Ironforge
Apr 09, 2010 04:09 |  #15
You might want to consider QNAP or Synology. Both are not bad compared to Drobo.
My Gears (external link) | Portfolio (external link)
3,572 views & 0 likes for this thread, 27 members have posted to it.
2957 guests, 129 members online
