I know I have found this in the manual before, but somehow now I'm missing it. I'm looking for the setting that tells the flash not to fire, but leaves the AF-assist beam enabled. Help!
Christina Senior Member 633 posts Joined Jan 2007 Location: Pittsburgh More info | Apr 09, 2010 08:01 | #1 I know I have found this in the manual before, but somehow now I'm missing it. I'm looking for the setting that tells the flash not to fire, but leaves the AF-assist beam enabled. Help! Christina - Pittsburgh Wedding Photographer
runninmann what the heck do I know? More info | Apr 09, 2010 08:28 | #2 Which body are you using? If it has flash control, you can disable the flash firing using the camera's menu.
GeneMan88 Goldmember 1,108 posts Likes: 18 Joined Jan 2005 Location: Portland, OR U.S.A. More info | Apr 09, 2010 08:33 | #3 MonteMama... 1D MKI + 1Ds MKI + 5D MKI Kit - EF17-35 f2.8L | EF24-70 f2.8 L | EF 100-400L IS | EF15 f2.8 | EF35L | EF50 f1.4 | EF85 f1.8 | EF135L | 580EX II | 580EX I | 270EX II | G12
Thanks for your responses. Christina - Pittsburgh Wedding Photographer
sethultimate Member 212 posts Joined Apr 2008 More info | Apr 09, 2010 14:11 | #5 GeneMan88 wrote in post #9962785 MonteMama... Depending on which camera body you are using. With my 10D... it was in the custom functions (C Fn 5). I don't know how much the custom functions menu has changed over the years... but I would hope it's still in there. It so much easier with these camera bodies. On my 1 series bodies... it's in the personal functions. I had to set it up via connecting my camera to my computer and using Canon's software to access the camera's personal functions settings (P Fn 15). Once set-up, I can change the setting in the camera... but it is rather counter intuitive... set to "off" and the beam is on... Set to "on" and the beam if off. Confusing, but once I figured it out I ran with it. Hope this helps. it's on the camera functions (5D). on 1Ds and 1Ds mark II I can't do that. I mean I can enable/disable the AF assist but I can't disable the flash from firing.
pipboogaloo Member 237 posts Joined Jun 2008 Location: newcastle upon tyne More info | Apr 09, 2010 15:30 | #6 Permanent banyes i cannot see it in my 1ds mk2 anywhere too 'i just ate a Nikonian'
toxic Goldmember 3,498 posts Likes: 2 Joined Nov 2008 Location: California More info | Apr 09, 2010 17:39 | #7 c fn 7-1 on the 5D
| Latest registered member is ealarcon 507 guests, 140 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
