Thread started 09 Apr 2010 (Friday) 10:21
wavy paper background problem
mjordanke
Apr 09, 2010 10:21 |  #1
I bought a new Colorama paper background, when I rolled it out in my studio I got the following problem: the paper on the ground is "wavy". It is straight when hangs in the air, but when it lays on the floor it becomes wavy.
You can see it here:
What could be the problem?
jxs1984
Apr 09, 2010 10:39 |  #2
look like air bubbles trapped in there? also i noticed the stand on the right is a bit lower than the left.
Nikon D810 · Tokina 16-28mm f/2.8 · Sigma 35mm f/1.4 art · Nikon 85mm f/1.8g
flickr (external link), facebook (external link)
, gear & feedback
aroundlsu
Apr 09, 2010 10:41 |  #3
I think you just need to pull it out more. I usually put sandbags on the edges of the paper to keep tension on it. You also need to put some sandbags on those light stands or they will fall down one day. Guaranteed.
Teddy Smith, SOC
IATSE Local 600 Cinematographer
mjordanke
Apr 09, 2010 10:50 |  #4
I tried to flatten out the air bubbles, put something on the edges of paper but the bubbles appeared again in new places.
Yes the right stand is lower on the photo, but it was equal to the height of the left in the studio.
When I pulled out about 6 meters on the floor I get the following result: first to meters were "bubbled", 2nd were straight and the 3rd again bubbled. I also tried to put a plexiglass on the bubbled are, but it push the bubbles to another place only :(
TMR ­ Design
Joined Feb 2006
Apr 09, 2010 10:54 as a reply to  @ mjordanke's post |  #5
If you don't see or feel any buckling or warping when the paper is hanging vertically then it does seem like you're just not pulling it out straight. I can't see a way for it to show itself on the ground but not when hanging. If you had buckles that large you would see it.
Robert
runninmann
what the heck do I know?
Gallery: 47 photos
Joined Feb 2006
Apr 09, 2010 10:54 |  #6
mjordanke wrote in post #9963526 (external link)
Are all the buckles on the same side? If so, you might have more tension on the opposite side (the side without the buckles). Go to the end on the side without buckles and pull that corner diagonally away from the buckles and see if that helps.
TMR ­ Design
Joined Feb 2006
Apr 09, 2010 10:56 |  #7
Hmm, that's really weird. If you're pretty convinced that it's in the paper then you can of course send it back but that's only worth it if the retailer will pay for the shipping.
Depending on the brand, some manufacturers will just write it off and send you a replacement. I had that happen once with a roll of Savage paper.
Robert
mjordanke
Apr 09, 2010 11:05 |  #8
I dont know that the paper is responsible for the problem. It is a strange thing owing to there is no problem when hanging vertically so the paper doesnt contains the bubbles, but when it lays on the ground the air bubbles comes.
I will test it and make a video about the problem tomorrow and post it here.
TMR ­ Design
Joined Feb 2006
Apr 09, 2010 11:08 as a reply to  @ mjordanke's post |  #9
If that's the case then it has to be uneven ground or uneven unrolling and laying it out.
What happens when you only roll out a few feet? Does it lay flat? If it does lay flat then at what point does it start to buckle?
Robert
runninmann
Gallery: 47 photos
Joined Feb 2006
Apr 09, 2010 11:09 |  #10
mjordanke wrote in post #9963639 (external link)
Are all of the buckles on one side of the paper?
Seanzky
Apr 09, 2010 11:13 |  #11
If it's not completely even when pulled out, it will do that. Pull it taut and pin it down on four corners if you want it perfect.
MrScott
Apr 09, 2010 12:24 |  #12
Psst - you might want to do a little dance on that paper before you put someone on it. That floor/paper combo looks pretty dang slippery without bags or tape...
Another test - does the paper wrinkle when its just on the floor and not suspended??? i.e. roll it out with the tube laying on the ground.
Finally, is the tube warped? Does it "bounce" when you unroll it?
Alejandro ­ Sandoval
Apr 09, 2010 12:28 |  #13
After few years working with seamless...that happens when
Your Background support is uneven
very humid weather
stored improperly seamless gets funny if is not stored in vertical position
Twitter (external link)http://www.twitter.com​/Ale_Sando (external link)
redefined
Apr 09, 2010 22:03 |  #14
Alejandro Sandoval wrote in post #9964133 (external link)
very humid weather
Going from that I'd say check the height of your support. Looks like the right side is lower than the left.
| Canon 7d | Sigma 27-70 f2.8 FOR SALE| Canon 24-70L f2.8 | Canon 430exII| Cybersyncs | Stands & Umbrellas | 1600 AB|
My Flickr! (external link)
RonnyMills
Apr 10, 2010 00:23 |  #15
Use a bubble level to make sure paper is level.
2,694 views & 0 likes for this thread, 11 members have posted to it.
1081 guests, 180 members online
