Thread started 10 Apr 2010 (Saturday) 14:12
dvd or cd?????
ddaayynnee
Apr 10, 2010 14:12 |  #1
i want to know which is should i buy blank DVD or CD to burn the pictures (800 pictures from Canon 40D) and i wanted to know if my old computer (that say hp cd writer) and would this can burn the dvd ? or only cd? lemme know as soon as u all can and thanks! need to know now
FaceBook (external link)
Website (external link)
LIKE?! (external link)
fibrepunk
Apr 10, 2010 15:33 |  #2
1. You probably want to fit everything onto 1 media, but we have no idea what are the size of the 800 pictures, so if you stick with CD, you might need more than 1.
2. Without knowing what model of the writer, we can't tell if it is capable of writing dvd or not, but according to your "hp cd writer" it appears that it is only a CD writer.
My Gears l HeatWare (external link)
- For Sale: Broken cameras for CLP
ddaayynnee
Apr 10, 2010 16:15 |  #3
AH I SEE
so i will go with CD and i will have to burn 2-3 CDs then and its 3GB-ish
SwitchBlade
Apr 10, 2010 16:26 |  #4
CDs top out at ~700MB so you'll need 4, possibly 5.
5D | 40D | Σ24 f1.8 | 50 f1.8 II | 85 f1.8 | 70-200 F4L | 540EZ x2 | Nissin Di622
themadman
Apr 10, 2010 17:37 |  #5
DVDs are more durable and last better from my experiences.
Will | WilliamLiuPhotography.​com (external link) | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
Vince(Chatham)
Apr 10, 2010 18:36 as a reply to  @ themadman's post |  #6
DVDs are alot cheaper to buy($) and hold lots more info.
Canon 50d/40D/ 2 Canon BG-E2N Grip's //[COLOR=black]100 2.8 Macro /24-105L / Sigma 150-500 mm /Tokina 12-24 F4 /[COLOR=black]50 1.[COLOR=black]8 /Kenko Ext. Tubes /580EX/
Sirui M-3204 Tripod /Sirui K20 [COLOR=black]Ballhead / Beike Gimbal head /Lowepro Computrekker Plus AW and Cotton Carrier.
fibrepunk
Apr 10, 2010 18:48 |  #7
ddaayynnee wrote in post #9970218 (external link)
AH I SEE
1. More like you will need 5 CDs for that amount of data.
2. I would recommend just getting a DVD writer like this one: http://www.newegg.com …aspx?Item=N82E1​6827151188 (external link) which is only $29.
- Make sure your computer uses SATA connection though since your system seem to be an older machine, else you will need to find a PATA DVD writer.
- It is really easy to install a DVD/CD writer into your computer.
- If you aren't familiar with installing computer parts, I reconnect getting an external DVD writer like this: http://www.newegg.com …aspx?Item=N82E1​6827151198 (external link) which is only $48.
3. Here are some DVDs I would recommend and this will probably last you a while: http://www.officemax.c​om …ku.jsp?productI​d=ARS30067 (external link) for $25 each spindle of 100 pieces.
themadman
Apr 10, 2010 18:53 |  #8
Verbatims are ok DVDs, I'd get Taiyo Yuden DVD, they are VERY good quality, I've used hundreds of them and I can't remember the last time I got a coaster from them. Plus they burn very well, from my testing of different brands with Nero CD/DVD Speed these have some of the lowest error rates.
http://www.supermedias​tore.com …l-8x-dvd-r-media-100-pack (external link)
Wilt
Apr 10, 2010 22:39 |  #9
Burnable CDs are fundamentally more archival than burnable DVDs, since the DVDs are burned using much faster rotational speeds, the organic dyes used in DVDs are fundamentally less stable!
Windows XP does not have DVD burning capabilities embedded into the O/S, but you must use application programs that can specifically burn DVDs. (example, an older version of Nero could burn CD but not burn DVD)
Taiyo Yuden would be the manufacturer of choice for me, too.
keitaro
Apr 10, 2010 22:43 |  #10
If you are using cd/dvd to archive your images, you want to buy high quality archival grade discs. From what I have read around here, people have mentioned that the standard discs you buy degrade over time compared to archival grade discs.
I think I remembered reading that usually archival grade discs have a gold coloured reading/write surface.
My flickr (external link)
LaaG
Apr 12, 2010 12:21 |  #11
Wilt wrote in post #9971758 (external link)
Thats actually an old myth from the days of CDs. DVDs burn better and last longer at 8x or more. CDs are also more prone to UV and fungus degradation since the dye layer is unprotected, unlike DVDs where the dye is sandwiched between two polycarbonate UV protective disks.
I would burn on a good quality DVD like Verbatim or Taiyo Yuden.
ben_r_
-POTN's Three legged Support-
Apr 12, 2010 12:48 |  #12
I only use DVDs as they hold more.
ddaayynnee
Apr 12, 2010 17:33 |  #13
i wanted to go for dvd but im only asking if my can burn or write on the DVD with a cd writer?
Wilt
Apr 12, 2010 17:55 |  #14
LaaG wrote in post #9980267 (external link)
Burnable CDs/DVDs can eventually ‘fade’, due to five things that effect the quality of CD media: Sealing method, reflective layer, organic dye makeup, where it was manufactured, and your storage practices. Like color films, keep all media out of direct sunlight, in a nice cool dry dark place, in acid-free plastic containers; this will maximize the lifetime of any media.
For CD media, Taiyo Yuden states Super Cyanine dye is chemically stable for at least 70 years, TDK states their metal-stabilized 'Cyanine' is also stable for 70 years, and Mitsubishi uses a Metal 'Azo' dye which they claim is stable for around 100 years. While azo dyes are chemically stable, the shelf life of media using Azo dyes typically does not exceed Super Cyanine and metal-stabilized Cyanine. A third dye for CD media is called 'phthalocyanine' dye, and this is typically marketed as more resistant to heat and UV radiation than Cyanine and Azo, but these are about the same tolerance.
DVDs also use organic dyes, but the manufacturers have intentionally kept dyes they use a secret. All blank DVDs are intentionally the same color Different dyes on CDs make blanks different colors, for DVDs it is not indicative of what dye, since they can be using different colored silver alloys and non-reactive additives in the dye.
Generally one should not use CD-RW, DVD-RW, or DVD+RW media in any form for permanent storage. DVD+R has superior error correction and burning control over DVD-R. The are debates about longevity of dye vs. phase change technology permanence.
I and many others have had burned DVDs sitting on shelves in the dark in acid free plastic containers, and had them fail within a few years. I even have a supplier-provided DVD with Photoshop LE which suddenly stopped being able to be loaded. I haven't had a burnable CD failure, in comparison.
Ultimately the issue is availability of devices to read digital data, and the Library of Congress has issues of data not accessible due to lack to device to read the media which was once recorded!
themadman
Apr 12, 2010 18:02 |  #15
ddaayynnee wrote in post #9982080 (external link)
No, get a quality DVD writer. DVD's have read issues mainly due to poor media and poor writer. (they are like $50, honestly)
2,401 views & 0 likes for this thread, 14 members have posted to it.
dvd or cd?????
2927 guests, 132 members online
