Thread started 13 Apr 2010 (Tuesday) 22:19
7D - question for people who had focus problems ...
wheresdavid
Apr 13, 2010 22:19 |  #1
I have a 7D which doesn't seem to be focusing properly and I would like to know from others who had "focus issues":
1) were you able to get the AF repaired to work properly and if so what did the repair center say?
The reason I ask this is that I have been traveling in Asia and Finally I was able to get to Bangkok to get my camera looked at. I told them the problem I was having: soft, oof and front focus/back focus problems with my L series lenses. I showed them examples of the problem. They checked the AF twice and said there were no problems. I had to leave Thailand but the problem continued. Finally I got so fed up of looking at a portfolio of soft shots - (granted there are some sharp shots but very few unless I am looking at shots from my 40D which are sharp) so I returned to Thailand from Laos to get the camera "fixed". I had written Canon US tech support twice explaining my problem and they told me they had never heard of such a problem.
I would like to be able to make sure I know what tests should be done to test the AF system in order to ensure that these tests are being performed when I take my camera to get repaired next Monday, April 19th. All I was told by Canon Thailand was that they tested the AF system on the computer and all was well.
I use single shot AF mode, with a single auto focus or spot focus point, usually the center one. At times it seems like the AF system is picking up the highest contrast area surrounding the selected AF point (again, I am using single AF mode, not expanded). I shoot a lot of portraits and environmental portraits. If I take a fairly close portrait I can get a sharp (but usually not tack sharp compared to my 40) shot. If I take an environmental portrait (the single focus point on the face of the subject) this is where the problems really start - back focus (focuses on a high contrast object behind the subject) , front focus (focuses on a high contrast object in front the subject), soft focus. By the way I shoot in RAW and process using Lightroom 2.6
Any input will greatly appreciated
bsmotril
Gallery: 11 photos
Joined Feb 2006
Apr 13, 2010 22:41 |  #2
Have have you tried the spot focus option for a single point? The actual focus sensor is quite a bit bigger than the square in the viewfinder, and it fill pick up the highest contrast objects it sees. The spot focus option shrinks the sensor so that it is just barely bigger than the square in the viewfinder. Also, if you could post some sample images with the EXIF data intact, that would help. Include a 100% pixel cropped view of a portion of the image where you think it is soft.
Galleries: http://www.flickr.com/​photos/smopho/ (external link) --- http://billsmotrilla.z​enfolio.com/ (external link)
wheresdavid
Apr 14, 2010 02:58 as a reply to  @ bsmotril's post |  #3
Thanks for the input, yes I do use spot focus most of the time but at times I do switch back to single-point AF mode. You brought up a good point about the focus area being much larger than the "square", I am aware of that but totally spaced out on thinking that may be a cause since I also was getting soft and just plain oof shots, especially when comparing shots with my 40D under similar conditions. So maybe some (all?) of the front back focus issues may be a result of the focus area being larger than what I think it is and thus it isn't actually back/front focusing but rather it is focusing "within" the actual focus area (on the highest contrast area) which is larger than the area I see inside the focus point. I have to keep in mind that I do have an actual front/back focus issue with my 135L lens.
I will upload work on uploading some examples. Thinking out load, I am now wondering if a lot of the soft shots are with my 24-105 wide open at 105mm.
Cheers,
Dave
artyman
Sleepless in Hampshire
Gallery: 17 photos
Apr 14, 2010 03:05 |  #4
The AF system must have some detail with which to work, and from what you say it seems the camera is picking the high contrast area withing your focus point which is what it is designed to do, so I can understand that Canon Thailand said it was OK. You also say your 135 lens is front focusing, so you need to test with a lens that you know is OK. You can of course micro adjust your 135 to correct the front focus on the 7D. Set up a proper test target to check the focusing is the only way.
Ken
riokid
Apr 14, 2010 03:27 |  #5
You may want to bring the 24~105 and the body together to Canon so they can check and calibrate both. Is the perceived focusing problem happening on all your lenses or just one lens?
Good luck :)
dan
Mostly Canon stuff
snyderman
Apr 14, 2010 08:02 |  #6
I'm one of the 'user-error' morons with a 7D that had focus issues. Much of what you have stated was present with my 7D before a trip to Canon US repair in NJ. Here is a written example of before and after repair issue:
Before repair shooting a bird in tree: Single-point focus, in one shot mode. Aim center focus point squarely on bird and ask camera to focus lens. Take 5 shots. On average, 1 in 5 shots bird would be in focus. The other 4 would randomly focus on something else in the frame, at times, maybe nothing at all in frame would be in focus.
After repair: Same setup, put singlepoint (center) focus point on bird. Five shots in a row with accurate focus on bird. Took 25 shots in single-point (center) in One-Shot and 24 achieved accurate focus.
The same 'random focus' issues showed up with all lenses with similar shooting conditions. Sports shooting, portrait shoots, still things, moving targets, etc. The camera would lock focus instantly, it just wouldn't lock ACCURATE focus most of the time.
Canon repair document said that they adjusted electrical contacts or something of that nature. The document didn't admit an actual REPAIR, but indicated 'adjustments' were made to the camera.
On a note of interest, they reset the camera back to original setup. I'm now starting to see that straying from initial camera setup to my own preferences, i.e., using the back button (*) as focus in AI Servo again causing focus issues. For example, my 70-200 f/2.8L IS lens is constantly 'hunting and jerking' for focus, so I know the camera isn't locking onto accurate focus. Also, when I move the single-point focus away from the center position, the keeper rate goes down.
I sincerely believe there are design issues involved with assigning camera functions and how they relate/interact with the new and improved focus system on the 7D.
What works best: Single point focus (center chosen) in One-Shot mode. This combination produces near 100% accuracy on my repaired 7D. As I move away from this mode and use the other focus features, focus accuracy decreases.
I'll continue to work with the 7D because it's capable of very high-quality results. Getting those results on a consistent basis is apparently something I need to completely understand and get a handle on how everything relates to the 7D focus system design.
dave
Canon 5D2 > 35L-85L-135L
lannes
Apr 14, 2010 08:22 as a reply to  @ snyderman's post |  #7
+1 on the Micro adjust, have a look at this before sending the body in
tstawarz
Apr 14, 2010 08:24 as a reply to  @ snyderman's post |  #8
I had a focus issue with my 7D and my 24-105. I did a micro adjustment because my real life shots were just not right. It took a micro adjustment of -20 to get sharp pictures. I sent the camera and the lens to Canon NJ and they came back perfect. It is now perfect with no adjustment at all. Some of my other lenses needed minor adjustments and some needed none at all. I am so happy with this camera.
5DIII gripped, 24-105L IS, 70-200 f/2.8L IS MKII, 100-400f 4.5-5.6L IS, 100 f/2.8 Macro,580 EX II Flash
riokid
Apr 14, 2010 10:51 |  #9
This link might help if you want to try microadjustment:
https://photography-on-the.net/forum/showthre​ad.php?t=750736
HTH :)
dan
Mostly Canon stuff
wheresdavid
Apr 15, 2010 01:24 as a reply to  @ artyman's post |  #10
At times, (I think) the AF is not picking the high contrast area within the autofocus point, it picks the high contrast area outside the AF point. I understand that the actual focus area is larger than the focus point we see in the viewfinder but this occurs when I use single shot AF mode with a single spot AF point.
wheresdavid
Apr 15, 2010 01:26 as a reply to  @ riokid's post |  #11
I'm afraid to do that. Last time when I brought the 7D with the 135L for calibration - what they did caused the 135 to be very soft on my 40D. I can't risk my 24-105 not working properly on my 40D. Unfortunately, I only have a few days in Bangkok so I can't risk it. Sorry, I just realized that my responses are going at the bottom of this post and not underneath the post that I am responding to.
shedberg
Apr 15, 2010 01:36 |  #12
snyderman wrote in post #9992584 (external link)
Hey Dave, just to clarify... using the back button focus was causing focus issues? When you use the shutter button half-press it was more accurate?
That's really interesting, I wonder if I should switch back as well...
6D / 7D / 16-35 II / 35 2.0 IS / 60 macro / 85 1.8 / 135 2 / 100-400 / 430EX II
wheresdavid
Apr 15, 2010 02:17 as a reply to  @ snyderman's post |  #13
Dave (Snyderman) your problems are exactly the problems I am having! I do shoot in single shot mode with spot AF. I don't lock and recompose. Following this things have improved slightly but I still have a low percentage of "Sharp" photos.
wheresdavid
Apr 15, 2010 02:18 as a reply to  @ shedberg's post |  #14
I don't use the back button to focus, I use the shutter release button to focus
wheresdavid
Apr 15, 2010 05:04 |  #15
Here are some cropped examples of soft/oof shots. how do you get the autofocus points to show on the photos using DPP?
IMAGE: http://www.fotosbydavid.com/photos/837497896_XYkEd-M.jpg
http://www.fotosbydavi​d.com/photos/837497889​_xG3MH-M.jpg (external link)
http://www.fotosbydavi​d.com/photos/837497882​_qaxJQ-M.jpg (external link)
http://www.fotosbydavi​d.com/photos/837497876​_NyP97-M.jpg (external link)
8,381 views & 0 likes for this thread
Latest registered member is MaryAxiom
957 guests, 218 members online
