Thread started 14 Apr 2010 (Wednesday) 14:03
1Ds Mark II vs. 5D Classic
Thunderbird33
Apr 14, 2010 14:03 |  #1
Has anyone here gone thru both, and what is the overall impression between them
Right now I have 5D and a 1D MArk III, but the AF on the 5D chaps my behind.....and was thinking that a 1Ds Mark II would be the perfect replacement for my 5D
What I would expect to be better in the 1Ds:
1) AF
2) lower Noise at higher ISOs on the 1Ds.
Quick thoughts appreciated, I can't test drive the 1Ds II :)
3) Also, I have three Mark II N batteries from a body that died, so I'd have extras!! :)
davidfig
we over look the simplest things
Apr 14, 2010 14:14 |  #2
I don't think the 1DsMII has lower noise. The 5D came out after it. With that said the 1DsMII is all around better in my opinion.
5D | 17-40L | Tammy 28-75 2.8 | 28-135 | 50/1.8 | 85/1.8 | Sony A6000 2-Lens Kit | SEL35 1.8 | EF 50 1.8 on NEX as my 75mm 1.8
philthejuggler
Apr 14, 2010 14:21 |  #3
Just bought a very low-mileage 1DS MKii and selling my 5D. I've only taken a few frames at low ISO but results are stunning (except for a white band left by a suspected faulty shutter :( )
Phil
Blog (external link), Website (external link) http://www.pho2u.co.uk …pher-in-northamptonshire/ (external link)
1DsIII, 5DIII, ZE21mm, 50mm 1.2, 85mm 1.2II, 135 f2, 580EXIIx2, X-Pro1x2, 18-55, 35 1.4, 60 2.4, EF-X20
themadman
Apr 14, 2010 14:22 |  #4
I also doubt the 1Ds2 has lower noise than the 5D but I don't really know. It can shoot 1 fps faster, but it's buffer can hold less shots (11 vs 17 I believe). It has an older metering system, but otherwise it is a very nice camera. It's major downside is it's price as it costs double what the 5D does and the differences are minor. The major ones being resolution and body design. For around $2k, I'd rather have a 5D2 in most cases. (Or a 5D + 7D :p)
Will | WilliamLiuPhotography.​com (external link) | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
Thunderbird33
Apr 14, 2010 14:32 as a reply to  @ themadman's post |  #5
Hmmm..it would set me back quite a bit to make the change. If I got 1500CDN for my 5d (4 batts, over two years left on full extended warranty) it would still cost me a grand for the one I'm looking at (2200 + tx, but with 3 year warranty).
But a second Mark III would only be an extra 400 or so......:cool:
The AF and ISO performance is a big thing for me.
Thanks for your input.
themadman
Apr 14, 2010 14:46 |  #6
Thunderbird33 wrote in post #9994844 (external link)
And Full Frame I take it? Or I would just say get a 7D, lol. I am willing to bet it has better ISO performance and better af for sure.
bobbyz
Apr 14, 2010 15:07 |  #7
I have old 1dmk2 and wanted to get 1dsmk2. Got a good deal on 5d but I still long for that 1 series AF. It is fine for studio though and I am slowly getting used to small size and lower weight.
Sine you mention AF, I would make the move to 1dsmk2.
Fuji XT-1, 18-55mm
elader
Joined Nov 2005
Apr 14, 2010 15:39 |  #8
I have shot extensively with both. The 1dsmkII is far more responsive, but I hated the LCD - when I was shifting studio lights around it was very hard for me to judge the results on the screen. The interface is also for the birds. (yes, I know, pro series, but the mkIII and mkIV abandoned the crazy two finger approach, right?)
At low ISO, the images from both are similar to me. Some have said that skin tones are better on the 1DsmkII, I haven't seen that. At high ISO, at the pixel level, the 1dsmkII is CERTAINLY noisier. But if you scale it down to 12mp, it's essentially the same. The 1dsmkII clearly has a bit more resolution.
The AF system in the 1dsmkII is wonderful, but I found the center point to be LESS sensitive than the center point of the 5D. I think that's well known. Again, in good light, it's terrific.
To me, it's not worth the extra cash unless you need the much improved AF Servo focusing or really rely on the outer AF points.
I traded the 1dsmkII up/down? for a 1dmkIII - not as nice of a sensor, but my customers can't see the difference and the cam is fast and accurate and the high ISO is astounding.
Eric
FJR1300 rider
5D mkIII and 1D MkIII
16-35L | 24-105L | 70-200L f/2.8IS | 85 f/1.8 / 50 f.1,4
Tawcan
Joined Apr 2004
Apr 14, 2010 15:39 |  #9
According to TheHoff and a few others who have used both 5D classic and 1Ds2 they are about the same in high ISO. However they mentioned that 1Ds2 images allow you a bit more pulling. If you want better AF then definitely go with 1Ds2. However the user interface takes a bit to get used to.
boblai.com (external link) |Facebook Fanpage (external link) | Flickr (external link)
blueM
"I am the Prince of Dorkness"
Apr 14, 2010 15:46 |  #10
If this is a 2nd/backup camera, why would you buy what you already have. Seems to me the advantage and flexibility of having a FF camera as a B-up outweighs the need for AF performance
Kevin
Thunderbird33
Apr 15, 2010 06:54 |  #11
blueM wrote in post #9995325 (external link)
For me, I like to shoot with my 24-70 on one body (5D at this time), and the 70-200 2/8 IS on the other body (MK III), but the AF points and performance on the MK III is so much better when I use the 5D I find myself getting annoyed with it's performance and like the idea of everything being the same with just the lenses being the difference.
I totally agree on the flexibility of the two, and a 5D image is awesome.
If I was handy, I'd try and fix my MArk II N paperweight myself. How hard can it be?? :)
ebann
Once an ugly duckling
Joined Jan 2003
Location: Chimping around Brazil since 1973! (Sometimes NYC)
Apr 15, 2010 08:04 |  #12
I have the 1Ds2 and 1D3 duo. I use my 1Ds2 for portraits and wide angle shots exclusively. I use my 1D3 for everything else. I am in the process of swapping my 1Ds2 for a 5D+$$$ and use that cash for some nice lens or lighting gear! Like Kevin said, the 5D works well as a backup and excels at what I need it for. No need to get $2000 stuck on a gear I don't use extensively... better get $1000 stuck on gear and the other $1000 stuck on new toys!
Ellery Bann
Fuji X100
6D | Rokinon 14 2.8 | 50 1.4
1D Mk IV | 24-70 2.8L | 70-200 2.8L IS | 135 2L | 400 5.6L
11,494 views & 0 likes for this thread, 9 members have posted to it.
1760 guests, 138 members online
