Thread started 15 Apr 2010 (Thursday) 06:56
Origional Digital Rebel/washed out photos
denbeau
Apr 15, 2010 06:56 |  #1
I have the original Digital Rebel. Lately most of my up close photos are washed out. Too bright. I'm not really knowledgeable about photography & do all my photos on the preset settings. I've tried different lighting and it used to be my best photos where in bright sun. Now everything is too bright.
Is there anything I do or is the camera too old? I've had it for about 6 years and use it a lot. I'm tempted to get a newer one, but hate to if I can get this one fixed.
Denbeau
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Apr 15, 2010 07:07 |  #2
These look a little overexposed. I take it that this is something new. Did you change any settings, even inadvertently, or do you feel the sensor or something is failing in the camera. I would look to make sure you didn't accidentally dial in some exposure compensation before you give up on your camera. That said, there are lots of benefits to be had with the newer dslr's if it turns out to be a hardware issue moving on would be preferable to a repair.
lannes
Apr 15, 2010 07:18 as a reply to  @ gonzogolf's post |  #3
Are you using apeture priority (AV mode), you may have inadvertantly dialed in some +exposure compensation. On the back you should see a AV+/- button just down and to the right of the viewfinder, if you press this and move the selection wheel, you'll see the metering marks move inside the viewfinder. This will allow you to set under or over exposure or adjust it back to the neutral position.
gjl711
Apr 15, 2010 07:19 |  #4
If something were failing I would guess that the metering sensor is failing, but it's more likely that you have maybe accidentally dialed in some exposure compensation. Posting the pics with EXIF intact would help.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
NOsquid
Apr 15, 2010 08:16 |  #5
What is the mode dial on top of the camera set to? Green box? P? Tv? Av?
denbeau
Apr 15, 2010 08:25 |  #6
Green box
It been going out for a while. Landscapes have been ok. A year ago I sent it in to Canon to get it cleaned and re-set factory settings. It didnt help this, nor did they tell me anything was wrong, it was a rip-off.
NOsquid wrote in post #9999363 (external link)
gjl711
Apr 15, 2010 08:38 |  #7
Could you have bumped it to a different picture style?
If not, there are two things I can think of.
#1. Do a hard reset of your camera. This can be accomplished by removing both the main battery and the backup battery for a few seconds. This will reset everything to factory defaults.
#2. Shoot in P mode instead of the green box. This will allow you to dial in -1 exposure compensation which will fix the problem in camera.
::Gear::
Scott_Quier
Apr 15, 2010 08:59 |  #8
The camera is fine. This is a case of pilot error.
The camera likes to meter so everything is 18% gray. The background is black. In this instance, to get the background to gray, it's dialed in more exposure for you. Try this for a solution:
  • Select Av mode
  • Select your desired aperture and ISO
  • Dial in about -1 stop of Exposure Compensation
  • Take the shot
I think you'll get the saturation that caused you to buy the camera in the first place.
Scott
Operation: Love Reunited (external link)
Check out my blog (external link) Gear List
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Apr 15, 2010 09:03 |  #9
Please read our sticky thread here;
https://photography-on-the.net/forum/showthre​ad.php?t=857871
It's mostly about focus issues, but all the pointers on how to ask the right questions and post usefull sample images applies to your issue as well.
CDS' HOT LINKS
egordon99
Apr 15, 2010 10:42 |  #10
denbeau wrote in post #9999040 (external link)
Here's the problem ;)
themadman
Apr 15, 2010 11:06 |  #11
denbeau wrote in post #9999404 (external link)
Green box
I don't think you got ripped off, I think it is user error. If you are using green box (fully automatic mode) that means the camera is pretty much choosing everything, don't expect the best pictures. A common mistake among beginner photographer is "if the photo is bad, it must be the equipment, if I buy more expensive equipment, my photos will look better." This is not true as the photographer is responsible for the photo, not the equipment.
I recommend you read up on exposure, and start trying to use the camera in Av mode or Tv mode and eventually using M mode when applicable. Forget about any mode other than Av, Tv, and M for now, you will be better off in the long run.
Pretty much Av lets you set the aperture and ISO and the camera takes care of shutter speed. In Tv you set the shutter speed and ISO and the camera takes care of the aperture. In M, you set everything.
Shutter speed is how fast the photo is taken. The faster the shot, the less light is let in, but the better the moment is "frozen." If shutter speed is too low, motion blur and hand shake can be an issue.
Aperture is pretty much how open the hole in the lens is set. Wider aperture lets in more light and has a thinner depth of field (less stuff in focus). Smaller aperture lets in less light and has a larger depth of field (more stuff in focus).
ISO is light sensitivity, higher the number, the brighter the photos, but also the more noise the photos have.
There are a lot of good threads in this forum, I recommend you read many and enjoy your time here!
By the way, what lenses do you have?
Will | WilliamLiuPhotography.​com (external link) | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
LaaG
Apr 15, 2010 11:17 as a reply to  @ themadman's post |  #12
Although some of the stuff he says are questionable, this quote may summarize your problem:
interesting read http://www.kenrockwell​.com …vs-5000-dollar-camera.htm (external link)
The color looks much better on the first image. The image you get with your mouse over the image is overexposed, so the colors are washed out. I prefer the warmer shadows on the first image.
Which is which? The first one (better color; my favorite) is the $150 Canon A530! The second image (worse color and exposure) is the $5,000 Canon 5D!!
This shows the importance of knowing how to use your camera over buying a fancier one. Cameras are just like cars: even if you have a Mercedes with automatic-tailgating, radar-controlled cruise control (Distronic) and navigation, you still need to keep it in lane with the steering wheel. A camera's steering wheel is the Exposure (light-dark) compensation control and the White Balance (color) control. Just like cars, regardless of how automated they are, they all need your help now and then.
denbeau
Apr 15, 2010 13:33 as a reply to  @ LaaG's post |  #13
Thanks to all with constructive suggestions.
End of thread.
IVIax
Apr 15, 2010 13:37 |  #14
denbeau wrote in post #10001164 (external link)
End of thread.
-Max
"Bad artists copy. Good artists steal." Picasso
scorpio_e
Apr 15, 2010 13:45 |  #15
^ They have had enough *LOL*
www.steelcityphotograp​hy.com (external link)
6,192 views & 0 likes for this thread, 13 members have posted to it.
2770 guests, 158 members online
