when using camera with 1.3 crop would you use 35mm or 50mm more for portraits?
britt777 Goldmember 1,148 posts Likes: 12 Joined Jan 2005 Location: Texas More info | Apr 15, 2010 10:16 | #1 when using camera with 1.3 crop would you use 35mm or 50mm more for portraits? Brittany
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Apr 15, 2010 10:45 | #2 What sort of portraits (what framing of the subjects) do you envision? What camera-to-subject distance do you use for your portraits? Skip Douglas
sinjans Senior Member 659 posts Joined Jan 2010 Location: Newfoundland and Labrador More info | Apr 15, 2010 11:44 | #3 I think you should go to your local shop and try out both to see which will suit your needs. I am in the same boat as you and am choosing the 50mm siggy
egordon99 Cream of the Crop 10,247 posts Likes: 3 Joined Feb 2008 Location: Philly 'burbs More info | Apr 15, 2010 11:53 | #4 britt777 wrote in post #9999986 when using camera with 1.3 crop would you use 35mm or 50mm more for portraits? Yes
Apr 15, 2010 12:10 | #5 I'd say 35mm for most waist to full body shots.. But that's just my taste in perspective A7RIII | EF15/2.8 FE | 16-35/4.0LIS | 24/1.4L II | ZA55/1.8 | 24-105G OSS
JelleVerherstraeten Goldmember 2,440 posts Likes: 1 Joined Dec 2008 Location: Antwerp, Belgium More info | Apr 15, 2010 12:33 | #6 |
Apr 15, 2010 18:38 | #7 Thank you, I no longer have any shops near me that carry these lenses...=( Brittany
elader Goldmember 2,374 posts Likes: 1 Joined Nov 2005 Location: Maryland More info | Apr 15, 2010 19:40 | #8 No lenses in Texas? On a 1/3 crop an 85 is a wee long. For head shots, the 50 is the ticket. Eric
K6AZ Cream of the Crop More info | Apr 15, 2010 19:50 | #9 Only you know what subjects you want to shoot and the distance from your subjects. Take a zoom and shoot at 35 and 50 to see which FL will work out best for you.
Apr 15, 2010 19:54 | #10 Even though only a smaller portion of the image circle is captured by the smaller sensor, wouldn't using a wide angle lens for portraits still introduce distortion that's generally considered undesirable for portraits?
Apr 15, 2010 20:02 | #11 |
K6AZ Cream of the Crop More info | Apr 15, 2010 20:12 | #12 britt777 wrote in post #10003312 no lenses in corpus christi. You have the body but no lens?
Apr 15, 2010 20:44 | #13 i have lenses. Just cant buy or test out lenses here in corpus. Brittany
K6AZ Cream of the Crop More info | Apr 15, 2010 20:50 | #14 First thing to do is use a zoom to figure out which focal length you need. Either that or rent one of each from a rental shop like LensRentals.com.
Apr 15, 2010 21:15 | #15 I just wanted to know which lens most people preferred when using the 1.3 crop camera for portraits. Brittany
| Latest registered member is Marcsaa 640 guests, 121 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
