Thread started 15 Apr 2010 (Thursday) 14:55
TECHNIQUE ADVICE NEEDED: stroboscopic
Cham_001
Apr 15, 2010 14:55 |  #1
Hi,
I urgently need advice on undertaking 'stroboscopic flash' photography.
Gear available: (travel-kit)
2 x 580exII with 3 x Pocket Wizard Flex TT5's
1 x tripod with cable-release
40D with EF-S10-22mm, EF28-105mm & EF100mm F2.8 Macro USM
(If push comes to shove I can get hold of umbrellas & modifiers - I will be loathe to using hired-in strobes)I will be shooting a martial-artist performing a 'flying-side-kick' indoors set in a gym. There will be a kick-bag that he will aiming at.
The martial-artist has specified these 2 requirements:
SHOT 1: that I capture a clear full-body image of him 'in-flight' as a single photo (without the kick-bag in view).
(CLEAR defined as: in-focus, 'filling-the-frame' and his face correctly exposed) - This I can do - easily enough, I will have plenty of opportunity to capture him using varying lighting techniques to create a bit-of-drama. :)
SHOT 2: that I capture him in a way that shows a sequence of him 'in-flight' as a single-shot. I believe that this effect/technique is called stroboscopic. - This is where I am probably out-of-my-depth and need advice on. I have never attempted this technique before. :oops:
Any advice/hints/tips on techniques will be much appreciated to accomplish this! - or How would you shoot SHOT 2
Location=Miami Dade // Date=Sat 24th April // Venue: tba // Time=1 hour
"... with a clear perspective - the confusion is clearer ..."
Body: < changing >
Lenses: 70-200mm f/2.8L IS II USM, 24-70mm f/2.8L II USM
Flashguns: 580ex II x 4, MT24 macro flash
Accessories: Pkt Wiz TT5 x 5, AC3 x 2, MiniTT1 x 2, Sekonic L-758DR
Studio Lights: Godox ADpro x 3
nyktrade
Apr 15, 2010 15:02 |  #2
To shoot #2: set your exposure setting to really underexpose the ambient, set shutter speed to slow, like 1/10th, and set your strobes to multi and set the frequency as appropriate.
Cham_001
Apr 15, 2010 15:47 |  #3
Thank you for posting this advice so rapidly - points duly noted & it seems the tripod & cable-release combo is very much essential to achieving this.
Have you tried anything similar - say for other individual sports where I can benefit further from you??
Body: < changing >
int2str
Apr 15, 2010 16:19 |  #4
Set your flash power to something manageable like 1/8th or so. Use the 40D (since it has 6.5 FPS) and set the camera to manual to get a properly exposed shot. Put the camera on a tripod and focus on the distance that the jumper will be. Then simply fire a burst of images and use photoshop to combine them.
int2str
Apr 15, 2010 16:21 |  #5
Here's an example:
http://www.youtube.com …zsbB5gqtY&featu​re=related (external link)
PacAce
Joined Feb 2003
Apr 15, 2010 20:19 |  #6
int2str wrote in post #10002170 (external link)
I agree. This is the way to do it.
There's no way the multi-strobe feature of your flash can be used to capture the #2 shot required by the client in a single frame. Even if you were able to get the ambient light not to register in the picture, the multiple images of the subject in the frame would come out looking translucent with the background showing through him.
...Leo
Mark1
Apr 15, 2010 20:53 |  #7
Actually there is a way to do it with the strobe feature. You just need to shoot it on a black background.
Joe McNally has a video showing how to do exactly what you are asking. Except it was shooting a ballet dancer. Of coarse it is with a nikon, but you will get the ides... http://nikonusa.com …9w/1/Repeating-Flash.html (external link)
mbellot
"My dog ate my title"
Apr 15, 2010 22:21 |  #8
Mark1 wrote in post #10003611 (external link)
Interesting video, but as PacAce said, the images are all translucent.
PacAce wrote in post #10003407 (external link)
Mark1
Apr 16, 2010 12:50 |  #9
But it is not the background that is showing through. It is the subject stacked on top of itself. Had they slowed the strobe down, or speed up the subject to where they are not stacked each would be able to stand on its own. Didn't think I had to go that 101 for everybody.
int2str
Apr 16, 2010 13:05 |  #10
Mark1 wrote in post #10007350 (external link)
It is the background showing through.
They'd stand on their own, but be slightly translucent :P
Why do you think he did the first "standing" exposure the way he did. Look at the difference that made.
Mind you, the "translucent look" is nice in a way too. It's not bad. But you have to consider your background well and get a lot of things right to make it work.
There's more than one way to skin a cat. For the OP's problem, I would think the multi exposure route might work better.
Mark1
Apr 16, 2010 13:15 |  #11
On black there is no background. So it is kind of hard for it to show through. What you are seeing is lack of light on the front of the dancer. On anything other than black I agree stacking the images is the way to go. But It most definatley can be done on black with strobe.
int2str
Apr 16, 2010 13:33 |  #12
Agreed.
Cham_001
Apr 16, 2010 14:51 |  #13
Thank you for bringing this vid to my attention. I think that this is very much the result that I am looking for. :cool:
My PS-CS3 skills are limited, so I will have to rapidly learn this app' to make this all work and come together.
I also came across this Ballet Dancer example by a chap named Nino who has posted on POTN in the section called 'performing arts'
https://photography-on-the.net/forum/showthre​ad.php?t=832743
So, now I have a few ideas to try! ;)
Body: < changing >
2,477 views & 0 likes for this thread, 6 members have posted to it.
1513 guests, 132 members online
