Thread started 17 Apr 2010 (Saturday) 12:10
Raw files no longer load (Ubuntu)
ions
Apr 17, 2010 12:10 |  #1
I changed the colour space on my 7D from sRGB to Adobe RGB. After doing so UFRaw, or any other raw editor I have installed, loads raw files like this:
So I switched back to sRGB. The problem remains. Every raw file I have taken since changing to Adobe RGB and back to sRGB loads this way. Raw files taken before the initial change still load properly.
To fix this I installed the icc-profile from the Ubuntu repos. Nothing changed. Any idea how I can fix this?
Gear: Canon EOS 5D3 | Canon EOS 7D | Canon 24-70L ƒ2.8 | Canon 100L ƒ2.8 | Canon 70-200 ƒ2.8L IS II | Canon 420 EX | Tamrac Evolution 9 | Crumpler 8 MDH | Manfrotto 190QC with 804RC2 head.
ions
Apr 17, 2010 14:09 |  #2
This is a jpeg (I shoot both raw and jpeg) of the same image straight from camera.
That raw image isn't a crop, that's how it opens.
No idea why my bbcode tags aren't working...
monty28428
Apr 17, 2010 15:17 |  #3
What profile are you using for the camera? (No profile, color matrix...etc)
ions
Apr 17, 2010 15:23 |  #4
This is happening with all raw shots in various settings.
monty28428
Apr 17, 2010 15:35 |  #5
when you click the color management button what does it look like??
monty28428
Apr 17, 2010 15:52 |  #6
certainly seems to be some type of profile issue -- your green for white balance is maxed out which just has to be wrong for one thing....
ions
Apr 17, 2010 16:22 |  #7
Changing settings in the colour management tab doesn't do anything positive. Because this happens in each raw editor on my computer (set to default settings) I don't think it has to do with a setting in an app.
monty28428
Apr 17, 2010 16:23 |  #8
Well I would say your raw files are corrupted then...
ions
Apr 17, 2010 16:51 |  #9
I considered that possibility so I tried using 3 different CF cards and all came up with the same result. I highly doubt it's the camera, how could it be just me having this problem if it were a problem with the camera?
monty28428
Apr 17, 2010 17:01 |  #10
My initial thought was a memory issue - but you can load older files and that seems to rule that out.
Try this -- copy one of your older raw files to a new name --- does it load fine?
Have you changed how you upload your files in any way??
ions
Apr 17, 2010 17:06 |  #11
An older file that worked still works after being renamed. Other than changing the colour profile as I said in the OP I've changed nothing else.
I found (external link) someone else using Ubuntu that *may* have the same issue, tough to tell.
monty28428
Apr 17, 2010 17:20 |  #12
sounds the same... purplish rectangle.
I just tried switching from sRGB to adobeRGB with my 7D and it uploaded to ufraw perfectly.. so I doubt that is the issue.
I can't think of anything else...
ions
Apr 17, 2010 17:28 |  #13
Huh. Rawtherapee works... Too bad it's so friggen slow on my computer.
monty28428
Apr 17, 2010 18:36 |  #14
Can you post a link to one of these raw files?
ions
Apr 17, 2010 19:47 |  #15
They're 7D sized... you really want one? Guess I could put one on one of those rapidshare type sites.
3,844 views & 0 likes for this thread, 4 members have posted to it.
1027 guests, 108 members online
