How do you stabilize your handheld camera while filming video? Let's see what are the different methods being used
mrmarks Senior Member 822 posts Likes: 11 Joined Jan 2010 More info | Apr 17, 2010 19:06 | #1 How do you stabilize your handheld camera while filming video? Let's see what are the different methods being used
lecherro Senior Member 809 posts Likes: 6 Joined Aug 2007 Location: Garland, Texas (Outside Dallas) More info | Apr 19, 2010 15:14 | #2 best thing you can do is zoom out. THe further you are out on the end of your lens the shakier you are. From there you can shoot in 60 frames and then speed up or stay at 60 fps. 60 fps is a really nice floaty feeling, that can hide a lot of shake. The "figrig" is nice. Steadycam JR, and so is "indiRAILSpro" Most importaant tho is to do some kind of support. Few and far between are those who can hold a camera steady with no support. First step........ Take the lens cap off.
LSV Senior Member 335 posts Joined Feb 2010 More info | Apr 19, 2010 20:17 | #3 The cheap alternative to steadycam types (though doesn't work as well), is to use your tripod. I borrowed a friend's manfrotto, and locked it in such a way as to have one leg in my pocket, and two legs on my shoulder. One hand on the threeway head, another on the focus ring. Four points of contact, fairly smooth even when slowly walking.
TimKostka Senior Member 342 posts Joined Sep 2008 Location: Bay Area, CA More info | I've used software stabilization called Mercalli Zenfolio
Terjay Senior Member 448 posts Joined Nov 2008 Location: Ylöjärvi, Finland More info | Apr 20, 2010 09:23 | #5 Tim Kostka wrote in post #10027789 I've used software stabilization called Mercalli Software stabilization isn't a cure-all. It can help, but if your footage has for example a lot of motion blur it just looks horrible. I've used Imagineer System's Mocha that comes with After Effects CS4 and it's also a great tool (if your footage is stabilizable of course).
lecherro Senior Member 809 posts Likes: 6 Joined Aug 2007 Location: Garland, Texas (Outside Dallas) More info | Apr 20, 2010 12:36 | #6 Also for a cheap steadycam effect you can use your tripos or monopod and add weights to the bottom of it and carry it around. the weights act to balance out any shake and your arm acts like the recoil arm of the real steadycam. its a little heavy but it works. First step........ Take the lens cap off.
peternap Senior Member 581 posts Joined Mar 2009 More info | You've already gotten some of the variations...but I use a monopole and lock the head so the camera is on the same plane as the shaft. I just put the leg over my shoulder like a Bazooka.
Apr 21, 2010 09:28 | #8 I use a Benro monopod w/ a small tripod at the base. Stuff and things
peternap Senior Member 581 posts Joined Mar 2009 More info | I made this last night with the monopole over the shoulder.
440roadrunner Goldmember 1,312 posts Joined Jul 2007 More info | Apr 21, 2010 10:30 | #10 Permanent banpeter nap wrote in post #10037268 .....PLEASE...don't start a gun debate... Google says......did you mean "Fotosniper?"
http://olhares.aeiou.pt/sniper_foto2628745.html 2-40D's, 30D, Xt, EOS-3, Elan7, ElanII 100-400L, 24-105L, 17-55IS 2.8, Sig 12-24 EX DG 4.5
peternap Senior Member 581 posts Joined Mar 2009 More info | No, I was talking about the people in the video. with a Manfroto ballhead.
ShayneThomson Hatchling 1 post Joined Aug 2010 More info | Aug 18, 2010 22:16 | #12 Here's a new camera mount that is suitable for video and DSLR's. www.steadyvision.info
peternap Senior Member 581 posts Joined Mar 2009 More info | Aug 19, 2010 16:28 | #13 Shayne Thomson wrote in post #10747680 Here's a new camera mount that is suitable for video and DSLR's. www.steadyvision.info There's quite a few different ways to shoot with it. That's pretty snazzy looking!
cwr89 Member 233 posts Likes: 2 Joined May 2009 Location: Cincinnati, Ohio More info | Aug 20, 2010 23:53 | #14 I started with a traditional $14 DIY steadycam Canon 5Diii | EF 24-105L | EF-40 STM | Tamron 70-200 2.8 VIDCII | 2x 580 EX | Canon G5X | 3x ProFoto D1|
| Latest registered member is semonsters 1470 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
