Thread started 18 Apr 2010 (Sunday) 15:55
50D dies, then resurrects
RT ­ McAllister
Apr 18, 2010 15:55 |  #1
I bring it to life by either:
1.) removing the lens - then reattaching it or...
2.) removing the battery grip and also reattaching it.
Happens once in a blue moon (again yesterday) but a royal pain in the arse when it does.
No logic - not the same lens either. I doubt it's the contacts because I own two 50D's and it happens on both. (One is not gripped though). I turn the camera on... then nothing. I don't even swap out the batteries first anymore because I know that's not it.
Humidity maybe? It's been pretty dry. Nothing is overheating because the camera can sit idle for an hour then fail to start until I perform the above voodoo.
tim
Light Bringer
Apr 19, 2010 02:06 |  #2
A 40D did the same thing, totally died in the middle of a ceremony, a week later it's ok again. Otherwise that series of cameras does hiccup occasionally. Not much you can do about it. I'm told 1 series cameras do it sometimes too.
RT ­ McAllister
Apr 19, 2010 08:38 |  #3
tim wrote in post #10021919 (external link)
Yes, I'm beginning to just chalk this up to the canon gods.
My 50D also last croaked during a ceremony. It was during a minister's speech so no big deal.
PMCphotography
Joined Sep 2009
Apr 19, 2010 18:33 |  #4
Occasionally my 40d's wheel will stop working. HAve to turn it off, take out the battery, and wait for a minute, then it's fine.
Never figured it out.
Twitter (external link)
Hobart Wedding Photography (external link)
I have some camera stuff. Here it is.
blackhawk
Apr 19, 2010 18:37 |  #5
Try a hard reboot, clear all settings manually, then pull both batteries. Make sure it has the latest firmware.
Make sure all contacts are clean.
May have a pcb failure if it keeps acting up, and especially if it gets worse. Always protect cams from moisture...
You got to know when to hold 'em, know when to fold 'em
Know when to walk away and know when to run
You never count your money when you're sittin' at the table
There'll be time enough for countin' when the dealing's done
monk3y
Totally Saturated
Apr 19, 2010 22:12 |  #6
PMCphotography wrote in post #10026480 (external link)
my 500D's wheel also stopped working 2x already in 6 months...it really scares the hell out of me specially when I am on vacation hehehe I just remove the batteries and let it sit for 5 minutes or so then put everything back and its ok again
blackhawk
Apr 20, 2010 04:44 |  #7
monk3y wrote in post #10027807 (external link)
One battery removal sometimes to cure "lense lock-ups" but the need for multiple hard reboots suggest deeper issues.
If you need to remove both batteries and it's happened multiple times, try reflashing the firmware.
Otherwise sounds like a hardware failure.
Another failed unleaded solder joint?
Yeah, no lead solder was a great idea, just like prescription vitamins.... thank the European Union for those swell laws that screwed up countless lives for a few dollars more.
deemarie
Apr 23, 2010 08:04 |  #8
My 50d has done this a few times too...hmmmm...
Namast'e
blackhawk
Apr 23, 2010 09:29 |  #9
deemarie wrote in post #10050327 (external link)
Try a "hard reboot" by pulling both batteries. This may cure it.
myride4runner
Apr 23, 2010 21:34 |  #10
get the 5d mark ii
2,253 views & 0 likes for this thread, 7 members have posted to it.
1594 guests, 136 members online
