Thread started 19 Apr 2010 (Monday) 04:52
Canon 7D - The magenta halo issue around bright lights
AlexMaragos
Apr 19, 2010 04:52 |  #1
Is there any efficient way to get rid of the magenta halo around bright lights?
[For both photography & video on the 7D]
The latest 7D firmware update 1.2.1 does not solve this issue.
Shot on 7D with the 50mm f/1.4
alexandrosmaragos.com (external link)
twitter.com/alexmarago​s (external link)
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Apr 19, 2010 05:44 |  #2
That is a lens issue, chromatic aberrations are a result of lenses, and the 50mm 1.4 is notorious for this wide-open. If you stop the lens down, this should go away at some smaller fstop.
That being said, the 7D does have more pixels on tap to record the CA, so just due to resolution alone, at 100% viewing, you may see more than previous bodies. since they had fewer pixels on tap. If a previous camera had just 2 rows of pixels to record this, the fringes would get averaged into those 2 rows, but the 7D would have 3 or 4 pixels to fully record this.
AlexMaragos
Apr 19, 2010 06:51 |  #3
Thank you for your words my friend.
The thing is that there is an amound of magenta halo even when i change lenses.
Not so huge like the 50mm 1.4, but is there.
District_History_Fan
Apr 19, 2010 08:18 as a reply to  @ AlexMaragos's post |  #4
Moist air (halo) and artificial lights...could this be a wb issue? Either way, I think it looks pretty cool. ;)
www.ericmcferrin.smugm​ug.com (external link)
jwcdds
Gallery: 1929 photos
Best ofs: 8
Joined Aug 2004
Apr 19, 2010 09:37 |  #5
Don't know.. is your white balance off? It's obvious the exposure is set to capture the boat/ship at night, which means any light would have a halo because the light would be blown-out (over-exposed). If the light was not suppose to be magenta, then you just need to adjust your white balance to make it the correct color. It won't, however, remove the halo because that's just over-exposure.
Julian
Tarzanman
Apr 19, 2010 10:15 |  #6
It is chromatic aberration. You won't eliminate it until you can bend the laws of physics at your will (and eliminate diffraction). Different wavelengths of light diffract at different angles. Short wavelenth = larger angle, which is why purple is the prevalent color.
The diffraction is more visible around areas of high contrast. Shoot your 50 f/1.4 wide open on a sunny day and you'll see what I mean.
4,217 views & 0 likes for this thread, 5 members have posted to it.
1680 guests, 136 members online
