How do you set your white balance?
Is a white balance card held with one hand in front of my lens the best method? Is that to close?
Apr 19, 2010 22:25 | #1 How do you set your white balance? Nikon D850 and a bunch of stuff, I have learned a lot here when I was shooting Canon, staying to keep learning..."Every time I set up I learn something new".
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Apr 20, 2010 05:32 | #2 If you are asking about setting up a "custom white balance", there are two things you must be sure of. One is that the card is held in light that is identical to that which is illuminating the subject. Also, you need to have enough of the frame filled to do the task properly. Read your camera's manual for the details. Skip Douglas
neilwood32 Cream of the Crop 6,231 posts Likes: 5 Joined Sep 2007 Location: Sitting atop the castle, Edinburgh, Scotland More info | Apr 20, 2010 06:54 | #3 That would get my vote as well Skip. It is so easy to change it in RAW, that it is almost silly not too. Having a camera makes you no more a photographer than having a hammer and some nails makes you a carpenter - Claude Adams
Grom Member 148 posts Joined Apr 2006 Location: Livermore CA More info | Apr 20, 2010 20:16 | #4 Here's the best one I've seen so far that teaches you how to do a white balance on a Canon or Nikon.. _______________
PhotosGuy Cream of the Crop, R.I.P. More info | Apr 21, 2010 09:43 | #5 It is so easy to change it in RAW, that it is almost silly not too. I sort of agree, but "almost" is a key word. Curtis N found that a blown red channel is a problem: I shoot in RAW and normally merely set the camera's white balance selector to whatever I determine the light source to be. At the very least, I do that, too. And FWIW, some people swear that AWB is OK outdoors. I'm not one of them, & be aware that AWB really sucks under artificial light. I ran a test indoors & have never used it since. Notice that the very last exposure in the 2nd image of tests was of a gray card, & it's way off. Also worth remembering is that the "correct" WB might not be right one for the scene. I often change the WB to suit the subject rather than the scene (maybe from daylight to cloudy or so on) as this can actually improve the "feel" of the image by warming or cooling it. Try taking a landscape sometime in RAW and try using different WB settings, you will get a different feel from each. Good idea. Is a white balance card held with one hand in front of my lens the best method? Is that to close? If you're using it to set a CWB, then there's no reason why it should be in focus. If you mean the card with the black/gray/white squares to adjust in PP, then I think it should be. FrankC - 20D, RAW, Manual everything...
| Latest registered member was a spammer, and banned as such! 2658 guests, 166 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
