Thread started 21 Apr 2010 (Wednesday) 00:26
tamron 17-50 paired with canon 24-70 on crop body
quynvan
Apr 21, 2010 00:26 |  #1
im looking to expand my lens collection and was wondering if pairing the tamron 17-50 with the canon 24-70 L is a good combination with my canon t1i? your input is greatly appreciated. thanks.
Canon T1i, 18-55mm IS, 50mm 1.8 Mk1.
mike ­ cabilangan
Apr 21, 2010 00:28 |  #2
if you already have the 24-70 ... i wouldn't buy the 17-50. i'd use your kit lens OR a 10-22
camera bag reviews (external link)
flickr (external link)gearLust
That_Fox
"In the Witless Protection Program"
Apr 21, 2010 00:30 |  #3
I'd look at something wider than the Tamron 17-50mm, because a 24-70mm will cover the normal focal lengths. Perhaps look at getting a Canon 10-22mm or a Tokina 12-24mm so then you'll be able to have a lot more versatility on the wide end.
Apparently I've been dubbed Foxy.
Alamy (external link), website (external link) and gear
Tee ­ Why
"Monkey's uncle"
Joined Feb 2006
Apr 21, 2010 00:38 |  #4
Personally, I think the 17-50mm gives a more useful range than the 24-70 on a cropped body. I think those two lenses have too much overlap to make it worth while. A better/more diverse set up may be an ultrawide with a 24-70, or a 17-50 with a 70-200mm lens.
Good luck.
Gallery: http://tomyi.smugmug.c​om/ (external link)
Combatmedic870
Apr 21, 2010 00:40 |  #5
I agree with everyone else. I mean unless your going to be leaving your 24-70 at home and using your 17-50 instead sometime. but carrying them both around would be a pain.
But I could understand not wanting to lug the 24-70 around and using the 17-50 instead, and then there being times where you want the 24-70 instead of the 17-50. Hell I would do that!
Same thing as people having a 16-35 and 24-70.
BUT if your going to be carry them both I think the Tokina 11-16 2.8 would go well with it!
Nikon D700: 16-35 F4, 50 1.4G, 85 1.8,105 VR Micro, 135F2 DC, 80-200 2.8 AFS
Olympus XZ-1
,Ryan
Sometimes, I think Photography is worse than Crack.:oops:
DreDaze
Gallery: 49 photos
Apr 21, 2010 00:52 |  #6
too much overlap in my opinion...i'd go 17-50mm, and something like a 70-200mm...or 10-20mm with a 24-70mm...
Andre or Dre
gear list
Instagram (external link)
jayvuu
Apr 21, 2010 00:59 |  #7
i would just get the 17-50 and see how it goes from there. the ranges are too close on those two lens.
Canon 5D MKII/Canon 17-40mm F4L/Sigma 50mm F1.4/Canon 430ex II
quynvan
Apr 21, 2010 15:10 |  #8
thanks for the replys.
FuturamaJSP
Apr 21, 2010 16:02 |  #9
I think you should try to shoot with the 24-70L for awhile and see the results :p
I wouldn't be surprised that you will find it a lot more versatile and produces higher quality images than the Tamron so all you really need is an ultra wide like one of those 10-20 something lenses
They asked me how well I understood theoretical physics. I said I had a theoretical degree in physics. They said welcome aboard! - Fallout New Vegas
blah blah blah
DA (external link)
watt100
Apr 21, 2010 16:31 |  #10
FuturamaJSP wrote in post #10039487 (external link)
actually on a crop model the Tamron 17-50 2.8 (non-vc) is significantly sharper than the Canon 24-70 2.8 L on all comparable focal ranges and apertures
www.photozone.de (external link)
FuturamaJSP
Apr 21, 2010 17:10 |  #11
watt100 wrote in post #10039638 (external link)
yeah... that's the same site that claims the kit 18-55 IS lens is just as sharp as 24-105L, 24-70L etc :rolleyes: :rolleyes: :rolleyes:
You may want to take a look at this:
http://www.the-digital-picture.com …omp=0&FLIComp=3​&APIComp=0 (external link)
http://www.the-digital-picture.com …omp=0&FLIComp=0​&APIComp=0 (external link)
another thing is sharpness isn't everything you should also take a look at CA, distortions, contrast etc. From what I have heard FF lenses usually performs better on crops because they crop out the less sharp corners :D
blah blah blah
DA (external link)
watt100
Apr 21, 2010 18:09 |  #12
FuturamaJSP wrote in post #10039877 (external link)
:D
uhhh.. no it doesn't - check it out for yourself !
:rolleyes::rolleyes::rolleyes::rolleyes:
it's easy to look up the MTF resolution numbers - go ahead!
ProD1gy_KiD
Apr 21, 2010 18:11 |  #13
17-50mm and 70-200mm f/4L IS
Bloodbean
Apr 21, 2010 19:10 |  #14
watt100 wrote in post #10040229 (external link)
Photozone.de isn't the be all and end all of information on lenses... ;)
Troy
7D, Rok 8mm, Sigma 10-20, Canon 17-55, Canon 50 1.4, Tamron 90 macro, 70-200L f4, FDn 135 f2, Sigma 170-500, Celestron C8 2,000mm f10
My Flickr page (external link)
toxic
Apr 21, 2010 19:12 |  #15
Get a 50-150 or 70-200 to go with the Tamron.
6,739 views & 0 likes for this thread, 19 members have posted to it.
Latest registered member is ahmed0essam
1583 guests, 174 members online
