Thread started 21 Apr 2010 (Wednesday) 01:14
Blending tree tops and eye bags
JBravo920
Apr 21, 2010 01:14 |  #1
So I'm doing some PP on my first senior portrait shoot. The skies were horrible that morning so I had to go out later that afternoon to grab some sky shots to add in as a background.
This is my original picture:
This is what I have done with PP so far:
I added the original picture as a layer on top of the sky picture, used the magic wand tool and magic lasso to take out the branches in the sky and add the more blue and cloudy background, as well as using the clone stamp on some of the trees to take out the closer branches.
My main question now is, how do I make the trees and the sky match up more so they don't look so fake and blended? And also, I lightened up the model to match the picture a little more and tried to fix a little bit of the darkness at her neck, however; I can't figure out how to fix the bags underneath her eyes. Is there an easy fix for this? Every time I try to lasso it and change the lighting, it completely changes the color far too much and seems to add a bit of noise.
I'm poor and using Photoshop Elements 7. Hopefully I'll be upgrading to CS4 soon, but this is all I have for now. Any help would be greatly appreciated. Thanks in advance for the help!
Gripped Canon XSi, Canon 18-55mm f/3.5-5.6 IS, Canon 28mm f/1.8, Tamron SP AF 90mm f/2.8 Macro, Sigma 28-105mm f/2.8-4, Canon 430EXII, Sigma EF-500 DG Super
Damo77
Apr 21, 2010 06:18 |  #2
I wouldn't try to magic wand the sky - in fact, I wouldn't try to select it at all.
Just overlay your sky on a new layer, then change the layer blend mode to Multiply. Then mask as necessary.
Those eye bags sure are severe. There's a bunch of different methods, I guess. Maybe some simple dodge-and-burn would do it, or I've seen some people mention using the clone tool set to "lighten" mode.
Damien
Website (external link) | Facebook (external link)
PixelMagic
Apr 21, 2010 06:54 |  #3
I'm sorry but you owe your client a reshoot in better conditions and using better techniques. The bags under her eyes are exaggerated by shadows cast by her orbital bones (eye socket). You need to use fill flash, balanced with the ambient light, to minimize the bags.
JBravo920
Apr 21, 2010 10:50 |  #4
PixelMagic wrote in post #10036354 (external link)
I told the mother that I did not want to do the shoot that morning. We were only able to shoot for about 45 minutes before it started pouring rain. I told her we needed to reschedule before we even met up that morning, she insisted that we do it then saying it was the only time they would be available. I've asked if we can re-shoot, so far they haven't been able. I'm not getting paid, it's for a my girlfriends co-worker's children.
So without being able to do another shoot, does anyone have any constructive criticism on what I'm able to do about this right now?
chrisa
Gallery: 180 photos
Apr 21, 2010 10:55 |  #5
post a link to the 2 images so we can work on them.
poloman
Apr 21, 2010 11:16 |  #6
The lighting was perfect for your shot that morning. Bright overcast is one of the best shooting conditions. You need to use fill flash to make your subject the most important part of the scene. I did give your image a tweak. I used a blue brush on a separate layer to color the sky, set the brush at 5%. I cloned out the little gaps to the left of the tree trunk as I though they where distracting. Her eye bags can be fixed with the patch tool in photo shop followed by edit/fade patch selection to make things look realistic. I opened a layer filled with 50% neutral gray and used a white brush set on 7% to lighten her face and hair.
If you don't have a speedlite, it might be a good early addition to your gear. Fill is most necessary on sunlit days. You could have used a reflector to help your situation here. This image is too small to really work with. I would normally have brightened her eyes and teeth a little.
A few notes for the future. She is facing out of frame and is too far to the left. Cropping some of the right side will help.
You will never get better if you excuse yourself after having trouble. Try to figure out what you can do to improve the next time you are in that situation. I too, would strongly suggest you reshoot this. Lower exposure of the background and use flash to brighten the foreground.
"All those who believe in psychokinesis, raise my right hand!" Steven Wright
syphlix
Apr 21, 2010 14:01 |  #7
as shot i'd say best thing is just to crop it close and leave out all that tree/sky stuff that as shot just doesn't add anything... it's way too blown out and even just adding a blue tint to it doesn't look natural... obv do some exposure bumps or brightness or whatever to bring her face back in...
like other people said... on a shoot like this extra lighting is 100% necessary... you would have been able to expose her well while keeping detail in the sky... a simple white fill card may have been enough (but probably not)... ah just saw you have a 430... use it next time :p
Check out my website/blog here! (external link)
My Flickr Photostream (external link)
glockamole
Apr 21, 2010 15:00 |  #8
You migth want to try a pixel mask, turning the background into a layer first and then have the sky stacked below. This works very well with some shots. Also, I'd do big crop.
1,576 views & 0 likes for this thread, 7 members have posted to it.
Latest registered member is rickldewitt
985 guests, 157 members online
