Thread started 23 Apr 2010 (Friday) 14:03
Guitar Photos: Strange string effect with reduced images.
dino8031
Joined Jan 2005
Apr 23, 2010 14:03 |  #1
This photograph is typical of the effect I'm trying to eliminate.
When the size of the photo is reduced from an original 10MB +/- JPEG to a size that I can post to the web of roughly 200kb, the strings appear to be braided. I can also see the same effect along the edges of the white pick guard.
Is there a way to fix this? The originals are fine.
IMAGE: http://img.photobucket.com/albums/v389/dino8031/stbodysideclose1200.jpg
tonylong
...winded
Gallery: 60 photos
Apr 23, 2010 14:19 |  #2
What software are you using and what steps and settings are you using to resize and compress the image (jpeg quality settings)?
Tony
snyderman
Apr 23, 2010 14:37 |  #3
same issue has happened with me during sharpening of images with my guitar photos. I don't know why it happens or how to stop it. I'll be interested to hear some ideas.
thanks for posting a similar pic. Nice strat, BTW!!
dave
Canon 5D2 > 35L-85L-135L
dino8031
Joined Jan 2005
Apr 23, 2010 14:40 as a reply to  @ tonylong's post |  #4
With these I'm just doing a quick conversion in a program called ThumbsPlus. You resize by entering one of the dimensions, in this case 1000 pixels wide and bump up the compression to a usable size.
I have CS3 and DPP, but I haven't used either for resizing.
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Apr 23, 2010 14:44 |  #5
Classic Moire artifact,.
when resizing, try fiddling with the bicubic smoother vs sharpen options...
CDS' HOT LINKS
tonylong
...winded
Gallery: 60 photos
Apr 23, 2010 14:46 |  #6
I'd say try out both DPP and CS3 and compare. In CS3 you also have some resize "bicubic" options and many sharpening options. What you posted looks pretty severe and you should have no problem coming up with much better. It's true that a diagonal thin line when enlarged a lot will show some stair stepping but your shot is over the edge.
Tony
kirkt
Apr 23, 2010 16:47 |  #7
You are getting aliasing artifact.
Kirk
number ­ six
fully entitled to be jealous
Apr 23, 2010 17:00 |  #8
Are all the strings helically wound? No single strands?
If so, it's Moiré, not jpeg artifacting. As CDS says.
Not much you can do about it - it's caused by interference patterns. It'll change if you change the angle of the strings in the picture. Experiment and you'll get the idea.
Like this: http://upload.wikimedi​a.org …e02.gif/150px-Moire02.gif (external link)
http://en.wikipedia.or​g/wiki/Moire (external link)
"Be seeing you."
50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash
Edsport
Apr 23, 2010 17:00 |  #9
Try sharpening after you resize...
Cameras - Canon 350D, 5D
Lenses - Canon 18-55mm, 75-300mm, 50mm f/1.8, 24-105L, 24-70L
Flashes - Yongnuo YN460 II, YN468
RF-602 transmitter and 2 receivers
jetcode
Apr 23, 2010 17:06 |  #10
bannedPermanently
To reduce the frequency of the aliasing you must place the strings as parallel to the sensor pixels as possible. This is a digital artifact called stair step in some circles.
sandro9mm
Apr 23, 2010 17:08 |  #11
Don't use crappy software, it's that simple :)
Photography Tips (external link) - Learn photography now!
Famous photographers (external link) - Video Interviews, photos, biography
My gear (external link)
number ­ six
Apr 23, 2010 17:09 |  #12
sandro9mm wrote in post #10053289 (external link)
I doubt that...
"Be seeing you."
sandro9mm
Apr 23, 2010 17:26 |  #13
yeah ur right :) but I didn't want to be rude.
kirkt
Apr 23, 2010 17:42 |  #14
Image magick resizing permits you to choose the filtering used during the resize operation, often givig better results in cases such as this. Also try sharpening very conservatively prior to resizing. Then, resize using bicubic (not bicubic sharper) then sharpen at the final size. You can also sharpen as you wish on a separate layer and paint back in the less aggressively sharpened strings.
Kirk
Kirk
MikeFairbanks
Apr 23, 2010 21:29 |  #15
I used to have that same model. Loved it. Should have kept it.
Thank you. bw!
6,380 views & 0 likes for this thread, 14 members have posted to it.
911 guests, 117 members online
