Thread started 24 Apr 2010 (Saturday) 12:56
How to properly test lens calibration.
net_tech
Apr 24, 2010 12:56 |  #1
Is there a set of rules I should follow when testing lens for front/back focusing?
I wanted to test my 16-35, but not exactly sure what to do.
So here is a list of my questions:
1. How far should I be from the object?
2. Should I zoom in to 35 or zoom out to 16?
3. Guessing I should use f/2.8 for my test shots
4. Should I use the center focusing point ?
5. Is there a problem if I keep the UV filter on the lens?
I will be testing on a tripod with a shutter release cable.
Canon 40D, 24-70 L f/2.8, 70-200 L II f/2.8, 100 L f/2.8 IS, 580EX II x 2
FOR SALE:
Flash Strap | SNOOT
FlyingPhotog
Cream of the "Prop"
Apr 24, 2010 13:02 |  #2
One fairly widely accepted method from Chuck Westfall...
Mount the camera to a sturdy tripod.
Position a reference target for the camera to focus on. The reference target should have sufficient contrast for the AF system to read, should be flat and parallel to the camera's focal plane, and should be centered with respect to the picture area.
Lighting should be bright and even.
Camera-to-subject distance should be no less than 50 times the focal length of the lens. For a 50mm lens, that would be at least 2.5 meters, or approximately 8.2 feet.
Set the lens for AF and the camera for One-Shot AF, and manually select the center focusing point.
Shoot at the maximum aperture of the lens via manual mode or aperture-priority AE, and adjust the exposure level if necessary to achieve an accurate exposure of the reference target. Use a low ISO setting to reduce noise.
If the lens has an image stabilizer, shut it off.
Use a remote switch and/or the camera's self-timer to release the shutter. Use mirror lock as well.
Take three sets of images at microadjustment settings of -5, 0 and +5, i.e, three consecutive images at -5, three consecutive images at 0, and three consecutive images at +5.
Examine the resulting images on your computer monitor at 100% pixel magnification.
Take additional sets of test images at different microadjustment settings if necessary until the sharpest image is achieved.
Register the corresponding microadjustment settings in the camera.
Here are a few additional precautions to observe:
• Do not attempt to autofocus on an angled chart, because doing so will degrade the consistency of the camera's focusing measurement. Keep in mind that the camera's AF sensor is comprised of multiple pairs of linear pixel arrays. If you attempt to autofocus on a single line in an angled focusing chart, only a few pixels from each active pixel array will "see" the target. Ideally, the contrast in the reference target should cover the entire area of the camera's center focusing point, and the reference target should be perfectly parallel to the camera's focal plane.
• For best results, manually set the focus on the lens to infinity for every exposure before allowing the camera to autofocus the reference target.
• Expect some minor variations in focusing accuracy within each set of three test images, even though they were all taken at the same microadjustment setting. This is completely normal, and is due to the tolerances of the camera's AF system.
• Expect smaller microadjustment settings to have a greater effect with telephoto lenses, and vice versa for wide-angle lenses.
• If you are attempting to set microadjustments for a zoom lens, it is important to realize that the camera's setting may only be accurate for the focal length setting you test. The instruction book suggests testing at the longest focal length of the lens, but you may find it more efficient to choose the focal length you use most often.
• Some EOS cameras and some EF zoom lenses may require more sophisticated calibration than the in-camera AF microadjustment settings can provide. In such cases, it may be necessary to have calibrations performed at a Canon Factory Service Center.
• Last but not least, there is no "official" Canon method for setting AF microadjustments, so this procedure is unofficial. If you think you can do better, then by all means, go for it. Towards that end, be advised that some independently made tools are designed to help you set AF microadjustments accurately. One of these is the LensAlign kit, due out soon from RawWorkflow.com:
Jay
net_tech
Apr 24, 2010 13:58 |  #3
CR2 file -> Link (external link)
FOR SALE:
Flash Strap | SNOOT
net_tech
Apr 24, 2010 14:27 |  #4
Camera is 8ft away from the object
100% crop
CR2 file - > Link (external link)
FOR SALE:
Flash Strap | SNOOT
4,055 views & 0 likes for this thread, 2 members have posted to it.
1458 guests, 172 members online
