I've owned both.
(since i'm into MMA/Boxing, i'll score them as if they're in a fight)
WEIGHT:
DRAW
They're both very light. Weight difference between the two are negligible.
BUILD QUALITY/FEEL:
CANON=10, TAMRON=8
The Canon just feels better in your hand.
The focus ring on the Canon is EXTREMELY buttery smooth.
The Tamron's focus ring is MUCH stiffer...
There's also a little play when you rotate from one direction to another which only gets exaggerated because of the innate stiffness of the ring.
Yes, when you're shooting macro you're better off moving the camera+lens back and forth. But when you're using MF for non-macro shots this can get frustrating. Which brings me to...
AUTOFOCUS:
CANON=10, TAMRON=9
Both have FTM override.
Canon USM focuses silently and locks focus fast.
Tamron focus movement has a high pitched hum but the AF speed was impressive. (about 85% as fast as USM)
Where the Tamron falls short is when it misses focus it has to go ALL THE WAY to infinity and back. (about 2-3 seconds)
IMAGE QUALITY:
TAMRON=10, CANON=8
The TAMRON's max magnification is actually 1:0.9 (or 1.1x) so it does a better job.
I got better sharpness from center to edge out of the Tamron vs the Canon (slight margin)
Not only that, the CANON's working distance (distance from front element to subject) is 3.5" vs. 4.0" on the TAMRON.
Yes, only half an inch but when you're up this close that extra 15% is DEFINITELY useable.
Along with the ability to go down to a fairly sharp and useable f/2.0, Tamron takes this one.
DETAILS WORTH MENTIONING:
Tamron provides a lens-hood. Canon does not.
Tamron's lens-caps have a pinch-release mechanism. Canon does not.
(easier to take off and put on, ESPECIALLY if the hood is on.
Also, right now Tamron has a $100 mail-in rebate on this lens valid til 12/31/2010.
From B&H, the Tamron is $489 shipped minus $100 mail-in rebate = $389
With Canon's instant rebate, it's $392 shipped.
FINAL VERDICT:
If you're NOT a CANON-ONLY snob, u can get used to the stiff focus ring, and can overlook the occasional to-infinity-and-back AF intermission then go with Tamron.
If you don't think u can handle the Tamron's quirks and don't need f/2.0 then go with Canon.
Hope this helps.
