Thread started 26 Apr 2010 (Monday) 21:34
Need help between two set of lens :(
Rivest
Apr 26, 2010 21:34 |  #1
Hi everyone. I need a little help on deciding what lens shoud I go with. I shoot a little of everything but I do more sports and portraits. I'm no pro but love shooting. I'm also on a really thight budget.
Right now, I have : 18-55mm IS | 55-250mm*| 50mm F1.4
I use the 55-250 for sports but it's too slow at 5.6. I want to buy hte 70-200 F4 but I just can't add it, I'm short on money. Here's my idea.
Sell the 55-250mm, sell the 50mm F1.4 (which I love starting at F2.0), get the 70-200 with that money and the 50mm F1.8 (hate downgrading...). I will keep the kit lens for wide shots.
Should I do that?
What would YOU pick?
A: 18-55mm | 55-250mm | 50mm F1.4 = +/- 650$
B: 18-55mm | 70-200mm F4 | 50mm F1.8 +/- 800$
EDIT:
C: 18-55mm | 70-200mm F4 = 700$
Any tips/help is greatly appreciated. Thanks for reading and replying :)
Hi, I'm David.
SkipD
Joined Dec 2002
Apr 26, 2010 21:40 |  #2
Try B minus the cheapie 50. Later on, if you really find a need for a fast lens shorter than 70mm you can work that one out. The 18-55 would be plenty for most portrait and snapshot work.
Skip Douglas
Rivest
Apr 26, 2010 21:48 |  #3
SkipD wrote in post #10071774 (external link)
But at 50mm, F5.6 would be too slow for me. I don't have a flash and hate using the internal one. I don't want to shoot indoor at 1600 iso. I'm really confused on what to do.
Is the jump from 5.6 to 4.0 really signifiant?
Hi, I'm David.
HeaTransfer
Apr 26, 2010 21:58 |  #4
70mm might be usable for portraits, depending on distance from subject.
As for losing the stop of light... what sorts of settings do you find yourself shooting at, at present (iso/shutter speed/aperture)? Assuming you're shooting wide open, going from 5.6 to 4.0 is a full stop... so you'll be able to halve your shutter speed.
What kind of sports are you shooting? Indoors? Outdoors? f/4 indoors will approach hopeless unless you're talking a brightly lit professional arena, in which case you might have a chance. For reference, I was at a NHL hockey game and had enough light to shoot at 2.8, ISO 1000 achieving shutter speeds of about 1/500 or slightly better on a Canon 40d.
Rivest
Apr 26, 2010 22:06 |  #5
I'm back from a shoot in a school's gym. Most of the shots where at ISO 1600 or 3200, you know how there seems to be plenty of light but it's not. I hate going at 3200, too noisy for my taste. I had an hard time doing action shots, F5.6 was too slow even at 3200. Gymnastic is wicked fast :P I need at least 1/200. Aperture, the wider the better, need to blur the background. Does that help make my choice?
Hi, I'm David.
Pennington
Apr 26, 2010 22:10 |  #6
For the sports shots, I don't think you'll find the difference between f/5.6 and f/4 to be that great. You can simulate it by kicking the ISO up a full stop - test it out to see if it would be enough difference.
Have you looked at the Sigma 70-200 f/2.8? I think it's still in the $800 range and you'd get two full stops faster.
I definitely wouldn't sacrifice the 50mm - if you want to shoot portraits, you'll want to keep a lens with shallow DOF. Even if you have to switch to the f/1.8 version, it's still a great little lens.
firedogg
Joined Aug 2004
Apr 26, 2010 22:11 |  #7
Forget the f4 lens and save up for a 2.8 version. If you get the f4 you will still be short on light for sports and still wish for the open aperture for portraits.
tkbslc
Apr 26, 2010 22:14 |  #8
Could you make a 100mm lens work? It's only half as long as the 200mm, but it is 4x as fast. That would be an even trade pretty much for the 50mm f1.4 and you could still use it for shallow DOF portraits with some room. If you are getting 1/200 at ISO 3200 f5.6, then the light really sucks. You really want 1/400+ for sports. F4 is going to get you barely there, but still at ISO 3200. F2.8 gets you 1/400 at ISO 1600. f2 gets you 1/800 at ISO 1600 or 1/400 at ISO 800 - which is really going to be a ton better.
Taylor
60D | ELPH 330 | iPhone 5s
HeaTransfer
Apr 26, 2010 22:15 |  #9
Can you get reasonably close to the action?
Try using the 50mm for indoor sports and crop. The T2i has a very dense sensor so you might be able to crop and retain good IQ as long as you're not super far.
peterbj7
Location: A Caribbean island in Belize and occasionally UK
Apr 26, 2010 22:16 |  #10
What's wrong with using ISO1600? Your camera should handle that with ease.
5D & 7D (both gripped), 24-105L, 100-400L, 15-85, 50 f1.8, Tamron 28-75, Sigma 12-24, G10, EX-Z55 & U/W housing, A1+10 lenses, tripods, lighting gear, etc. etc.
"I prefer radio to television. The pictures are better"
ceegee
Apr 26, 2010 22:17 |  #11
I think you'll find that f/4 isn't enough for indoor sports. On the other hand, for outdoor sports the 70-200 focuses really quickly, much faster than the 55-250, and you'll see a big difference there. It's also a terrific portrait lens (as is the 55-250).
If it's an indoor sports lens you're wanting, I don't think you'd gain much with either of your scenarios.
Gear: Canon 7D, Tokina 12-24 f/4, Canon 24-105L f4, Canon 70-300L, Canon 60 macro f/2.8, Speedlite 580 EXII, 2x AB800
Website (external link)
Rivest
Apr 26, 2010 22:18 |  #12
tkbslc wrote in post #10072070 (external link)
Could you make a 100mm lens work? It's only half as long as the 200mm, but it is twice as fast. That would be an even trade pretty much for the 50mm f1.4 and you could still use it for shallow DOF portraits with some room.
Are you talking about that 100mm F2.8 macro? I thought about it but for football (soccer) it might be too short. I like having long range but is it worth sacrifying speed?
Hi, I'm David.
tkbslc
Apr 26, 2010 22:18 |  #13
peterbj7 wrote in post #10072081 (external link)
He said he had a hard time getting 1/200 at ISO 3200. That's not cutting it. I guess he could try 6400, but that is not awesome even on a t2i.
Taylor
Rivest
Apr 26, 2010 22:22 |  #14
HeaTransfer wrote in post #10072076 (external link)
I can get close to the field, but if the action is on the other end, that makes it far.
Too slow when inside. I also like a lot more using 800 than 1600. I find IQ realyl better in the first.
ceegee wrote in post #10072094 (external link)
I'd say 20% indoor, 80% outdoor.
Hi, I'm David.
xarqi
Apr 26, 2010 22:24 |  #15
Rivest wrote in post #10072101 (external link)
He may have meant the 100/2. How big are you printing? Cropping may be a viable option.
3,479 views & 0 likes for this thread
Latest registered member is chuckm
919 guests, 311 members online
