Home Depot does have it. There's where I bought mine. It comes in 4'x8' sheets though. So consider that when you go to pick it up! I had an interesting drive home with mine.
If you search around in these forums, you'll find more discussion in white tile board, including the actual Home Depot part number that they can use to locate it in the store.
Cameras: 1DX, 1D4, 20D, 10D, S90, G2
Lenses: Canon 10-22mm, 16-35mm f2.8L II, 24-70mm f2.8L, 70-200mm f2.8L IS, 300mm f2.8L IS, 200mm f2L IS, 50mm f1.4, 50mm f1.2L, 85mm f1.2L, 1.4x TC, 2x TC, 500D macro, Zeiss 21mm
Lighting: 580EX, Elinchrom 600 RX's, D-Lite 4's, ABR800, 74" Eli Octa, 100cm/70cm DOs, Photoflex Medium Octa and reflectors, PW's, Lastolite Hilite, Newton Di400CR bracket
