imahawki wrote in post #10091340
Sorry.
500mm, F10, 1/320, ISO 100, on a 50D. I've messed around quite a bit with the micro adjust (in this image it is zeroed out). It doesn't appear to be front or back focusing, it just appears to be soft.
Consider those settings, I'd say it is very sharp!
At 500mm, even with IS (OS) I would have it at 1/500 on a crop frame camera. Also at f10 the 50D is gonna have softness due to diffraction issues, it's limit is around f7.6.
Also how did you micro adjust it? Canon recommends you microadjust at a minimum of 50x focal length, at 500mm thats 25 meters (around 82 feet minimum!)
If you really want to test for sharpness, get a sturdy tripod, a remote trigger, and turn on mirror lockup and repeat the test.
Good luck! (but honestly, it looks fine)
