Thread started 19 Jul 2005 (Tuesday) 14:35
EOS 20D and 420EX compatability
Jarhead
Jul 19, 2005 14:35 |  #1
I recently purchased an EOS 20D. I have a 420EX that I use with my 35mm. How compatable is the 420EX with the 20D? Or should I face the fact that I should consider purchasing the 580EX. Any advice is appreciated!
JZ
tbfoto
Joined Dec 2004
Jul 19, 2005 14:55 |  #2
The 420EX is 100% compatable. Its a very good flash. Use it without worry.
Titus213
Jul 19, 2005 18:29 as a reply to  @ tbfoto's post |  #3
What kind of answer is this? Sure, it's 100% accurate, but aren't we supposed to encourage the purchase of new equipment? How is a persons supposed to get purchases by the spouse if they aren't recommended?
That being said, the 420EX will work great but....if you add a 550EX or a 580EX you will have a master and slave set-up that would be dynamic in many situations and definitely improve your photography.:lol:
Oh, and welcome to the forums...
Dave
Perspiring photographer.
Jarhead
Jul 20, 2005 06:56 |  #4
I can't remember where I read that the 420EX does not compensate for the 1.6x lens difference that the digital have over the 35mm. Should this be a concern and if so, how is this hurdle crossed?
scottbergerphoto
Joined Jun 2003
Jul 20, 2005 07:10 as a reply to  @ Jarhead's post |  #5
The only currently available flash that can utilize that aspect of ETTLII is the 580EX. I wouldn't worry about it. I use (3) 550EX's and have no interest in a 580EX at this time.
One World, One Voice Against Terror,
Best Regards,
Scott
ScottBergerPhotography (external link)
David1943
Jul 20, 2005 07:28 as a reply to  @ scottbergerphoto's post |  #6
Very sensible - Unless you really need huge power over a long distance with a tele lens then the 550EX is just as good at a significantly cheaper price.
Happy snapping, David :)
Regards, David
Canon black 300D with Grip, 18-55 Kit Lens, 28-300 Tamron XR Di LD, Canon 550EX Speedlight, Olympus C-720, Canon EOS600, 28-200 Sigma, Canon EOS1000F, 35-105 Canon.
MadMesh
Jul 21, 2005 15:57 |  #7
i love flash
Canon 20D w/ 18-55 Lens Kit, 6 gigs CF Cards
580ex & 420ex Flash, tripod, Canon case, tripod, various filters
Canon ELAN 7 & 14mm L Prime for Landscapes
50mm f/1.8, 70-200 IS L,
Canon White EF-S 10-22 L
IBM T40 Thinkpad
Apple Power Mac G5 w/ Photoshop CS, 2 Gigs Ram, 600 GIGs Storage, and a 20.1" Widescreen LCD to help thoes 8 megapixels shine. :evil:
1000 Gigs Rackmounted RAID server storage comming soon.
condyk
Africa's #1 Tour Guide
Jul 25, 2005 12:00 as a reply to  @ scottbergerphoto's post |  #8
I get interested in flash every now and again but then get bored again :D However, I did see an ebay advert for a 'bargain' Sigma 500 Super that said it was 'compatible with ETTLII' ... now compatible is one of those tricky words that could easily lead me astray, so what does it mean in this context?
Is the 500 worth buying and so saving some money over for the Canon options, for a 'general use but might get more excited' kinda user like me? I was thinking the 550 Canon as an alternative more than the 580.
https://photography-on-the.net …/showthread.php​?t=1203740
scottbergerphoto
Joined Jun 2003
Jul 25, 2005 12:36 as a reply to  @ condyk's post |  #9
You need the Sigma 500 DG Super to work with wireless ETTL.
Best Regards,
Scott
blue_max
Jul 25, 2005 12:41 as a reply to  @ condyk's post |  #10
I was a flash sceptic myself until recently. I wanted to shoot people against a window and flash was the only way to balance the exposure. As your main interest is wildlife, I guess you wouldn't have much use for it.
Graham
Lamb dressed as mutton.
puttick
Joined Mar 2002
Jul 25, 2005 12:51 as a reply to  @ blue_max's post |  #11
I looked into this in some detail before buying a 420EX for my 350d. It works perfectly. It is true that the focal length information sent to the flash from the lens causes the flash to "zoom" itself as if it is attached to a 35mm full-frame camera, but this would tend to spread the light over a wider area than is coverd by the "1.6x crop" sensor - i.e. some light is wasted - and at least this means coverage is even with no drop-off.
However I have found I need to set the FEC to +1 stop - but having done this, exposures using flash are very accurate indeed. To determine this correction, I only needed to shoot about 5 exposures and check the histogram. Your 20D should behave the same way.
The 420EX is a lot smaller, lighter, and less expensive than the 550/580EX flashes, and can always be used as a slave if you later buy a higher rated unit.
Nigel Puttick
North Yorkshire, UK
condyk
Jul 25, 2005 12:52 as a reply to  @ blue_max's post |  #12
Yes, I remember that thread. It was an interesting one. Flash would have worked with some of the closer Swan shots I've taken recently where the white areas were blown out (UK?? Sun??!!) ... and who knows I may well develop a new interest once I get one, especially in the UK which is a bit sparce on big game :lol:
Is there any problem getting a SH 550, for example, which would be similar priced to the new 500 DG Super that Scott mentioned, i.e. does anything need replacing after significant usage?
scottbergerphoto
Joined Jun 2003
Jul 25, 2005 15:46 as a reply to  @ condyk's post |  #13
A well maintained (not abused )550EX will last you for many years.
Best Regards,
Scott
robertwgross
Joined Nov 2002
Jul 25, 2005 21:59 as a reply to  @ scottbergerphoto's post |  #14
How do you abuse a 550EX flash?
Call it dirty names, like Vivitar?
---Bob Gross---
Titus213
Jul 25, 2005 22:34 as a reply to  @ robertwgross's post |  #15
---Bob Gross---
...or Sigma?
Dave
3,328 views & 0 likes for this thread, 12 members have posted to it.
1739 guests, 172 members online
