Stacking is only the first step in post processing all that image data you collected. Hopefully you also shot Dark Frames for each Light frame you shot, in addition to Bias/offset frames, and Flats and Dark Flats. Usually when someone first starts astrophotography with a DSLR and learning to stack their images they tend to ignore those. They are however important to a good image.
After stacking with DSS how did you save the image and what other post processing did you do, and with what processing software?
After stacking the image will look very dark. You must save it for further processing in something such as Photoshop.
I typically save my images to 16 bit Tiffs, with changes embedded, Not applied! I don't use DSS to make any color or luminance adjustments. I save all that work for better software more suitable to the task.
After stacking and saving the stacked image to whatever file name of your choice, you will need to open your image in Photoshop and start the post processing with a histogram stretch. You do this with Levels and Curves adjustments. Doing this will bring out the data you're not seeing in the DSS Stacked image.
There is much more to it than just stretching the histogram to manipulate and enhance your image data, but that's a start. You will want to be careful not to over stretch it clipping the dark points too much, A mistake many of us make. Space is dark but it's not black!
Further processing will include things like Noise Reduction, and, maybe a little localized Curves and Tones Adjustments to emphasize certain areas and bring out more detail.
