Thread started 02 May 2010 (Sunday) 22:16
cr2/jpeg filing
dennisatmph
Joined Nov 2003
May 02, 2010 22:16 |  #1
dear friends
currently i download using DPP software, and I am able to give all my photos the date, name, in a whole batch from the SD card in the camera connected to my PC via USB.
i understand there is something called hyperdrive out there where i can download my pics there, but will i loose this ability to label my pics like i can from the way described above.
If not, I am going to buy the lightest notebook to travel with me, seeing that the netbook cannot load the DPP easily and work becuase of low screen resolution.
thanks much for sharing your insight.
dennis
ps I have never seen one of those hyperdrive things.
canon 5 d mark 2, canon 50 prime 1.2, canon 17-40 L , 580EXII , 430 EXII
rvdw98
May 03, 2010 10:14 |  #2
I assume you're referring to this?
http://www.hypershop.c​om/category-s/119.htm (external link)
This is basically a fancy image tank, much like the Epson P-series. You use it as a portable means to offload images from your flash card to a higher capacity hard drive while on the road. That way, you don't have to buy a boat load of (comparatively expensive) flash cards to hold everything you shoot during your trip. Then when you return home, you copy the contents of the image tank to your computer and process your images just like you normally would.
Roy
dennisatmph
Joined Nov 2003
May 03, 2010 20:49 |  #3
rvdw98 wrote in post #10112241 (external link)
Thanks for your insight. Yes I have seen that somewhere on teh internet.
But I guess my questions is that when you down load all of your pics in there, how will the filing of the name work? will it be like 0001.jpg, 0002.jpg, or can you label each one like you can in DPP software like 2010 05 01 Dad's party 0001.jpg, 2010 05 01 Dad's party 0002.jpg etc etc
Otherwise I wll just buy a light cheap computer to download photos
Dennis
rvdw98
May 04, 2010 01:47 |  #4
dennisatmph wrote in post #10115787 (external link)
The image tank will copy your flash cards verbatim, using the original folder structure and filenames. When you get back to your computer, you use your regular downloading process to rename, label, sort, etc. your images as you like.
The image tank is just a go-between: instead of downloading your images directly from your flash cards, you now download them from the image tank. The rest of the process remains the same.
Roy
dennisatmph
Joined Nov 2003
May 04, 2010 19:10 |  #5
rvdw98 wrote in post #10117232 (external link)
Thanks much for your insight. So do you mean to say that it is like a bigger flash drive, where you dump it all into the "hyperdrive"and then when I go home, plug it into my computer , and down load the photos with DPP canon software?
rvdw98
May 05, 2010 02:24 |  #6
dennisatmph wrote in post #10122184 (external link)
Yep. :D
Roy
810 views & 0 likes for this thread, 2 members have posted to it.
cr2/jpeg filing
2789 guests, 140 members online
