Thread started 03 May 2010 (Monday) 11:25
Open in CS5 - CS4 - Driving me nuts!
taygull
May 03, 2010 11:25 |  #1
It is driving me nuts that the images open in a single window with tabs!!! I can't seem to find out how to change this. I want the images to open in their own window as it makes it easier to drag them into a new layer.
www.chrisfritchiestudi​os.com (external link)
McKinney, TX
TTk
May 03, 2010 11:33 |  #2
Go to in CS4/CS5,
Edit
Preferences
Interface
Enable floating document window docking..:D
Terry.:cool:
http://www.terrykirton.co/ (external link)
http://www.ttkphotogra​phy.com/ (external link)
http://www.langtoftpho​tography.com/ (external link)
 (external link)
taygull
May 03, 2010 11:55 |  #3
OK..it was the "tabs" check box! Just didn't see it before!
Thanks!
McKinney, TX
ssim
Joined Apr 2003
May 03, 2010 11:55 as a reply to  @ TTk's post |  #4
It is a matter of personal preference but I have really taken a liking to the tabs. If you want to copy a layer to another image in all of those tabs all you have to do is being on your source image and the layer you want to copy. Having the Move tool selected drag from your image (not from the layers panel but in the image itself) and then hover your cursor over the tab you wish to copy to. Once this image opens on your screen let go of your mouse. If you select shift before letting go of your mouse, it will center the new layer on the target image.
I found it awkward at the beginning when they introduced this in CS4 but became a convert after using it for awhile.
hawkeye60
May 03, 2010 11:58 |  #5
In CS5, in the top tool bar- float all windows:
It's a lens not a lense!
The truest test of character is what you do when you think no one is looking.
René ­ Damkot
May 04, 2010 04:38 |  #6
ssim wrote in post #10112788 (external link)
QFT.
Takes a bit of time to get used to, but it works.
You can (just like a web browser) also drag the tabs into a new order, or drag them into a separate window BTW.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
taygull
May 04, 2010 16:26 |  #7
I just don't see the need to have them in tabs? Maybe I'm missing something but how does it make it easier to drag one onto another when working with layers?
Typically I'll have one image open but may have various textures, album pages, sloppy borders, etc...
McKinney, TX
René ­ Damkot
May 06, 2010 08:46 |  #8
It gives a cleaner interface IMO.
And it's easier to switch between certain images.
Then again, it's a personal preference thing ;)
ssim
Joined Apr 2003
May 06, 2010 09:27 as a reply to  @ René Damkot's post |  #9
I agree with Rene on all points.
I already said in an earlier post that it is a personal thing and it really is. So many come on here and try to convince others (not this thread) that their workflow is the right one when the right one is the one that that the end user feels comfortable with and gets the job done.
I have found myself hating the floating windows, one is hidden behind another and then you have to resort to the drop down to select the right file. Perhaps I just wasn't organized enough on my workspace or had too many files open but I find the tabs great to work with. I'm not saying it is not without its trials and tribulations in the learning process but it certainly has improved my workflow and that is all that matters now.
taygull
May 06, 2010 13:41 |  #10
I agree Sheldon, I always like the idea of a better workflow. I know mine is not very good.
So with that said if you use the tabs what is the best way to drag image on tab one on top of image on tab 3? I like the idea of tabs but adding them to other layers has caused me to be frustrated.
McKinney, TX
ssim
Joined Apr 2003
May 06, 2010 16:18 |  #11
taygull wrote in post #10133405 (external link)
I am not sure I understand your question for sure but the process is really quite simple. On your source file (the one you are copying from) you select all the layers that you want to move to a new document. With your move tool selected you click and hold on the image (not the layers panel, has to be the image) and drag your cursor and hover over the file tab that you want to drop these into. This tab will open and you can move your cursor over the image and let go. Voila your selected layers from the source file are now there. If you hold now shift before letting go they will center on the new image.
The trick is to not let go of your mouse once you start to drag them from your image. Depending on your system resources it may take a moment for the target file to open when you hover over its tab.
I did a quick little screen capture video (this isn't my thing) that shows this. Drag Tab (external link)
taygull
May 06, 2010 18:04 |  #12
aaahhhh...OK...now that I took an attitude that I don't know everything this actually works pretty well! I'll turn tabs back on and try it for awhile!
Thanks Sheldon!
Now if my plugins would only be 64 bit compatible life would be much better! At least I did figure out how to open CS5 in 32 bit mode!
McKinney, TX
tim
Light Bringer
May 06, 2010 19:15 |  #13
I like tabs now too, I didn't to start with. You can use window -> convert all tabs to windows (or whatever) if you need them in windows occasionally.
Badger
Joined Jun 2005
May 07, 2010 04:20 as a reply to  @ tim's post |  #14
The thing I am having trouble with is the main document window doesnt seem to be joined to the panels at the edges.
If I want to go to another application that is open,,,it doesnt all go behind the other app (i'm on a mac by the way!) the toolbars go behind but the doc window stays wehre it is.
ie, if i use alt+tab to switch between open apps the document window always stays at the top even though the panels and bars disappear behind. :confused:
Janice
Canon EOS 40D, Canon 70-200mm f4, Canon 50mm F1.8, Tamron SP 28-75 XR Di f2.8, Sigma 10-20mm, Sigma 105 macro.
René ­ Damkot
May 07, 2010 10:04 |  #15
Badger wrote in post #10137269 (external link)
https://photography-on-the.net …52311&highlight​=blue+line
That's how it has always behaved...
Only difference is that since CS4 you now have an application frame, which is new for Mac.
Press Ctrl+Cmd+H to hide PSCS4.
3,941 views & 0 likes for this thread
Latest registered member is Arti
1029 guests, 316 members online
