Hello. I have experienced my 5D2 freezing on video mode when I use 1/100 and faster shutter speed. just wondering if anyone of you experience this. Thanks.
ralliart_04 Senior Member 260 posts Likes: 3 Joined Aug 2008 More info | May 03, 2010 16:59 | #1 Hello. I have experienced my 5D2 freezing on video mode when I use 1/100 and faster shutter speed. just wondering if anyone of you experience this. Thanks. Canon 6D/ 7D2 / 50 F1.4 / 70-200 F2.8L IS II / / 135L / Fuji X-T1 / Fuji 23 F1.4 ; Flashes: 2 x Yongnuo 600
sportsshooter50 Member 249 posts Joined Nov 2008 More info | May 03, 2010 17:10 | #2 Would you be using a Sandisk Extreme III, 8GB cards? There have been problems with video using them. I had to send one to Sandisk for an exchange for hanging on video in the 5d Mark II.
May 03, 2010 20:35 | #3 hmmm...that is one good suggestion right there. I am using Sandisk 16 GB Extreme III, 8 GB Extreme III and Extreme II's. I should try to observe which one causes the problem. I was suspecting that but I did not really zero in on that one. Canon 6D/ 7D2 / 50 F1.4 / 70-200 F2.8L IS II / / 135L / Fuji X-T1 / Fuji 23 F1.4 ; Flashes: 2 x Yongnuo 600
oldvultureface Goldmember More info | I had problems with a 4GB Extreme III in a 7D. Buffer would fill and recording stopped. The camera did, however, recover gracefully. The card was exchanged by SanDisk and all is well.
May 03, 2010 22:37 | #5 I tried to run just over a minute of video using 1/125 shutter speed and the 16GB and 8GB extreme III's. looks like the camera did not freeze this time. I will try again tomorrow. both cards are formatted last Saturday. Maybe it has an effect as well. Canon 6D/ 7D2 / 50 F1.4 / 70-200 F2.8L IS II / / 135L / Fuji X-T1 / Fuji 23 F1.4 ; Flashes: 2 x Yongnuo 600
sportsshooter50 Member 249 posts Joined Nov 2008 More info | May 03, 2010 22:46 | #6 ralliart_04 wrote in post #10115701 hmmm...that is one good suggestion right there. I am using Sandisk 16 GB Extreme III, 8 GB Extreme III and Extreme II's. I should try to observe which one causes the problem. I was suspecting that but I did not really zero in on that one. Was there any problems after the exchange? The exchange has worked flawlessly.
borealis Senior Member 257 posts Joined May 2005 Location: yukon More info | May 04, 2010 03:56 | #7 Interesting. I've had similar issues with Extreme III cards with my 7D and 5D2. I think I'll write Sandisk a little note. Thanks! "There is no point in having sharp images when you've fuzzy ideas." - Godard
May 04, 2010 08:37 | #8 In order to let Sandisk know, I can just contact them via their website, right? Canon 6D/ 7D2 / 50 F1.4 / 70-200 F2.8L IS II / / 135L / Fuji X-T1 / Fuji 23 F1.4 ; Flashes: 2 x Yongnuo 600
sportsshooter50 Member 249 posts Joined Nov 2008 More info | May 04, 2010 14:37 | #9 Yes, all my contacts were via their web site.
| Latest registered member is semonsters 1045 guests, 111 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
