Thread started 03 May 2010 (Monday) 21:44
Kenko 1.4x DGX - No image quality loss?
rockygarcia
May 03, 2010 21:44 |  #1
Just picked up the Kenko 1.4x DGX and, albeit after only a limited amount of use, can't see any image quality loss. Is this possible?
IMAGE: http://i99.photobucket.com/albums/l283/phoneydg/4043.jpg
1DX | 17-40 F4L | 24-70 2.8L | 50 1.8 | 85 1.8 | 200 2.8L for sale | 70-200 2.8 IS IIL | 300 F4L | 100-400L | Kenko Pro 300 1.4x DGX | 2x Canon Tele III | 430EXII
themadman
May 03, 2010 21:45 |  #2
Teleconverters tend to work well with nice prime lenses. Was this with the 300 f4L?
Will | WilliamLiuPhotography.​com (external link) | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
rockygarcia
May 03, 2010 22:01 |  #3
themadman wrote in post #10116123 (external link)
Yup, that was indeed the 300!
phreeky
May 03, 2010 23:06 |  #4
CA much?
There is almost always SOME quality loss, but they can certainly still be used effectively. For example if you had avoided that really high contrast part of the scene it would've looked a lot better.
edit: In here: https://photography-on-the.net/forum/showthre​ad.php?t=867326 the first two are 400mm with the 1.4x, the third is the 400mm with the 2x. The 2x shot looks ok at that size with a little clean-up, but at full size you can see I missed the focus a touch and it is also a bit soft (and it's cropped a bit as-is, so cropping without a TC wouldn't work).
Cameramonger
May 04, 2010 01:47 |  #5
I tried a series of test shots with and without the Tamron 1.4x TC. They were controlled by keeping the camera on a tripod in the same place, zooming in and out to get the same field of view. On a 50mm prime, of course I had to move the camera to keep the same image with and without the TC.
I was amazed. Even in lab-like conditions, viewed at a variety of apertures at 200% crop, there was just about no perceptible difference. On cheaper lenses, the TC actually helps, since it uses only the middle of the lens image, so the soft corners are gone! This is one of the rare times in life when it is good to "cut corners"!
Of course, in real-life use, the loss of 1 f-stop can be a factor. However for daytime outdoor nature or portrait shots, this is rarely a problem.
...Cameramonger
S2K.OGRAPHY
May 04, 2010 02:16 |  #6
i need to pick up one of these to use with my 70-200
sebr
May 04, 2010 02:35 |  #7
I have been using a Kenko TC with my 135L and sharpness is excellent. CA is more noticeable when shooting wide open, but it is still rather good.
Sebastien
5D mkIII ; 17-40L ; 24-105L ; 70-200L II ; 70-300L ; 35L ; Σ85/1.4 ; 135L ; 100macro ; Kenko 1.4x ; 2x mkIII ; 580EXII
M5 ; M1 ; 11-22 ; 18-150 ; 22/2.0 ; EF adapter; Manfrotto LED
Benron Tripod; ThinkTank, Lowepro and Crumpler bags; Fjällräven backpack
dongson
May 05, 2010 01:42 |  #8
I received mine today, really excited!
I tried it first with Tamron 200-500mm, amazingly, at max focal length (700mm f8 ), I still can focus !!!
So, 500mm + 1.4TC + 1.6 Cropped Body = 1000mm ? (please correct me if I am wrong)
The exif file at max reads: 700mm (on cropped body)
here is a test shot (460mm, F8 ) this pic has no sharpening but does added a little vibrance
And this is at full zoom 700mm with ONLY resize, no PP
And the setup :)
IMAGE: http://farm5.static.flickr.com/4009/4579681590_7970b195e6_o.jpg
Canon EOS 5D Mark II, 24-105mm f4L, 70-200mm f2.8L IS Mark II, 16-35mm MK II f2.8L, Prime 135mm f2L, 100mm Macro 2.8L IS, Prime 85mm f1.2L Mark II, Tamron 200-500mm f4-6.3, Speedlite 580EX-II. 430EX II, Britek 550W Strobe lights, Sekonic 780HR, Pocker Wizards FLEXTT5 x 2
phreeky
May 05, 2010 05:49 |  #9
dongson wrote in post #10124132 (external link)
I believe that is F/9.
Here is my extreme use of the 1.4x: 20D->2x->1.4x->400mm F/5.6. 100%, lens wide open. So 1120mm F/16.
RandyS
May 05, 2010 06:05 |  #10
Ok, you're wrong. It (basically) equals a 700mm lens. But since you're only using the center of it you get the same field of view as you would with an 1120 mm lens on an ff body. Technical nit picking I know, but it's not an 1120mm lens.
Also, you need to remember that you're cropping the field of view of the TC as well as the lens itself.
So it's not : (.4 + .6 X focal length) + focal length.
It's : ((.4 X focal length) + focal length) X 1.6
dongson
May 05, 2010 14:09 |  #11
Thanks for corrected me on that, I never good at that :) and yeah, it was a f9 (Not f8 ) - it was 2AM in the morning :D
Sonny
RandyS wrote in post #10124720 (external link)
dwarfcow
May 10, 2010 03:47 |  #12
anyone tried taking a picture of saturn with a 400 2.8 +2x tc +1.4x tc on a 7D body?
"Evidently the photo shop at the college I go to is one of the best in the country. They actually have a handful of digital medium format cameras for students to use; Haliburtons, or hasslehoffs, or something like that."
-name withheld to protect dignity.
Toys
phreeky
May 10, 2010 04:10 |  #13
Focusing should be easier with live-view and F/8, was bloody hard through a 20D VF @ F/16!
dwarfcow
May 10, 2010 04:14 |  #14
phreeky wrote in post #10152777 (external link)
yea, i saw yours, pretty cool, i don't have a tracking tripod mount, so i'm hoping the f8 will help with the speed of the little dot, and getting a little xtra crop-reach outta it (and hopefully some more sharpness w/o the faster shutterspeed of 2 stops for less motion blur. Live view has been amazing for focusing on the moon, just zooming in to 10x on the lcd makes it much more obvious than the viewfinder when its right on.
Toys
5,485 views & 0 likes for this thread, 9 members have posted to it.
1440 guests, 133 members online
