Well as you can see i have the cheapest and most generic beginner lenses one can have which means its time for a much needed upgrade.
Basically i want to upgrade the telephoto first, then the "all around" which my stock lens is pretty much doing, then probably just keep my nifty and get a 85 f/1.8 a little later.
Anyway, i work for my college's newspaper and shoot a lot of events, interviews, and sports(indoor and outdoor). Just mentioning if that helps at all.
I was thinking the 70-200 f/4 (will be a gift so i dont want to be obnoxious push for the 2.8). That will really serve as my sports lens and since i get press passes i can get close enough to the action that 200 should suffice. That will be used for baseball, softball, track, lacrosse, and indoor basketball. (i am allowed to use a flash indoors so it shouldnt be a problem)
What i really need is a suggestion(s) to replace the stock lens. I would prefer that it is an EF mount over an EF-S just because i'm planning on upgrading my body to a 1D series body, most likely a MarkII N once my 20d craps out on me. I am not opposed to non-Canon suggestions. And i know the choices will be limited in number because i would rather have EF so just throw out suggestions and never mind the price factor (although cheaper is better, quality is far more important)
Anyway, let the suggestions start rolling. Some photos taken with the lens would be great as well. thanks a lot guys
Btw, i know i could have used the search function but i think i am one of many that cant actually decide on a product based on forum comments without someone advising me personally hahaha
And used lenses are certainly not out of the question
