Thread started 04 May 2010 (Tuesday) 08:55
Sigma 120-300 F2.8 with Tele ??
BigStig
Some say that he is a CIA experiment that went wrong, and that he only eats cheese...
May 04, 2010 08:55 |  #1
So I borrowed a Sig 120-300 F2.8 to try out. Love it and bought one.
When I put on my Kenko 1.4 teleconverter. the max App was F5.6
I new I would loose 1 stop of light so I expected it to drop to F4
Is this normal or am I missing something??
Cheers SteveP
Cheers SteveP
http://stevephilipson.​com/ (external link)
My Gear CPS Member
POTN Feedback https://photography-on-the.net …rch.php?searchi​d=25290946
plasticmotif
May 04, 2010 09:26 |  #2
Tried it with another converter?
Mac P.
My Zenfolio (external link) My Photo Blog (external link) My Equipment
https://photography-on-the.net …p?p=14172975#po​st14172975
BigStig
May 04, 2010 10:04 |  #3
No I only have the one.
Cheers SteveP
My Gear CPS Member
BigStig
May 04, 2010 10:05 |  #4
Also I have not tried it on the lens I bought yet but I will tonight.
Cheers SteveP
My Gear CPS Member
BigStig
May 06, 2010 10:41 |  #5
OK so the camera must think it is a 2x tele when mounted to this lens because it shows as a 240-600 in the meta data. Strange.
Has anyone used a 1.4x teleconverter with this lens and managed to set at F4?
Cheers SteveP
My Gear CPS Member
XsiBrian
May 06, 2010 12:58 |  #6
Try the teleconverter on another lens. If it also shows as a 2x then the teleconverter needs to be fixed.
On a side note, the difference between a 1.4x and 2x is the 1.4x shorts all 3 extra contacts while the 2x leaves the middle one open. It could just need a cleaning.
Riverlander
May 06, 2010 18:15 |  #7
I use that exact combination and the combination reports to the camera correctly.
NOTE You must put the teleconverter on the lens and then mount the combination on the camera. Do not add the teleconverter to the camera and then mount the lens -- you will get errors.
I also use a Sigma 2x teleconverter with the 120-300 and it also reports, and works, properly -- f/5.6 and auto-focus etc.
Canon; 7D with grip, EF-S 10-22, EF 24-105L, 580EX II flash, 550EX flash, 430EX flash, Sigma; 18-50 f/2.8, 50-150 f/2.8, 120-300 f/2.8, 50-500 f/4.5-6.3 OS, 30 f/1.4, 150 Macro; Sigma APO 1.4x and 2x converters, Benro M-257 tripod & B-1 ballhead. Wimberley Sidekick. Lots of other stuff.http://riverlander.smu​gmug.com/ (external link)
BigStig
May 13, 2010 10:37 |  #8
Thanks that did the trick I have to put the tele on the lens then to the camera. I was doing it the other way around.
Cheers
Cheers SteveP
My Gear CPS Member
Tapeman
Sliced Bread
Joined Jan 2004
May 13, 2010 11:12 |  #9
I have never had any problems attaching teleconverters to camera & lens in any order.
Is that peculular to Kenko or Sigma?
Canon G1X II, 1D MKIV, 5DSR, 5DIV, 5D MKII, 16-35/2.8L II, 24-70/2.8L II, 70-200/2.8L IS II, IS, 100-400/4.5-5.6 L IS II, 500/4 L IS II, 24-105/4 IS, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, 2X MKIII,580EX II, 550EXs(2), ST-E2.
Gitzo 1228, 1275, 1558, Lensbaby 3G. Epson 3880, Bags that match my shoes.:)
plasticmotif
May 13, 2010 11:24 |  #10
Tapeman wrote in post #10173986 (external link)
Me either. That's odd.
Mac P.
Riverlander
May 14, 2010 01:26 |  #11
I do not know whether it appplies to all TCs, but it is in the instructions that came with both my Sigma TCs.
phreeky
May 14, 2010 01:39 |  #12
I believe it's an oddity with Sigma lenses. My Sigma 150mm acts strange when mounted in the "wrong" order (but in my case it thinks the TC isn't even there).
3,153 views & 0 likes for this thread, 6 members have posted to it.
1605 guests, 140 members online
