I have a 7D and a 50mm 1.4 incoming. Was that a smart buy considering I already own a 60mm 2.8 Macro? I've heard a lot of people with the 60mm have sold their 50.
May 04, 2010 12:17 | #1 I have a 7D and a 50mm 1.4 incoming. Was that a smart buy considering I already own a 60mm 2.8 Macro? I've heard a lot of people with the 60mm have sold their 50. .
May 04, 2010 12:25 | #2 If you need to shoot faster than f/2.8, then having both is good. 7D | 300D | G1X | Tokina 11-16mm f/2.8 | EF-S 17-55mm f/2.8 | EF-S 60mm f/2.8 Macro | EF 85mm f/1.8 | 70-200 f/2.8L MkII -- flickr
james_in_baltimore Senior Member 494 posts Joined Jun 2006 Location: Baltimore, MD More info | May 04, 2010 12:25 | #3 Well, the 50mm is a full 2 stops faster, so that is a pretty big difference. They are similar focal lengths though, so it might make more sense to have a 100mm macro or the 85 1.8. James Harris Photography - Weddings Portraits Events
May 04, 2010 12:47 | #4 Well, once the 50 shows up, I'll make up my mind. I originally got the 50 for sharper images, but from what I've been told, the 60 is almost just as sharp. If the 60 is just as sharp, I may just stick with that. .
picturecrazy soft-hearted weenie-boy 8,565 posts Likes: 780 Joined Jan 2006 Location: Alberta, CANADA More info | May 04, 2010 13:03 | #5 nebulight wrote in post #10119934 Well, once the 50 shows up, I'll make up my mind. I originally got the 50 for sharper images, but from what I've been told, the 60 is almost just as sharp. If the 60 is just as sharp, I may just stick with that. sharpness is completely the wrong reason to decide whether to keep a these lenses or not. -Lloyd
NinetyEight "Banned for life" More info | May 04, 2010 13:08 | #6 nebulight wrote in post #10119934 Well, once the 50 shows up, I'll make up my mind. I originally got the 50 for sharper images, but from what I've been told, the 60 is almost just as sharp. If the 60 is just as sharp, I may just stick with that. In my experience the 60mm Macro is razor sharp and I actually sold my 100mm macro because I found it too long for my uses (on a 1.6x crop body) and i found it slightly sharper as well. Kev
Accessoire Goldmember 1,119 posts Joined Oct 2009 More info | May 04, 2010 13:10 | #7 I ended up getting rid of the 1.4 when I got my 60 macro, but picked up the 1.8 just-in-case
crcal Senior Member 808 posts Likes: 1 Joined Nov 2009 Location: Honolulu, HI More info | The 60mm macro is very very sharp. It's a macro lens so it's slower to focus. But I'd take it any day over the 50mm f/1.4. Calvin
nightcat Goldmember 4,533 posts Likes: 28 Joined Aug 2008 More info | May 04, 2010 13:38 | #9 nebulight wrote in post #10119934 Well, once the 50 shows up, I'll make up my mind. I originally got the 50 for sharper images, but from what I've been told, the 60 is almost just as sharp. If the 60 is just as sharp, I may just stick with that. If you think the 50mm will be sharper than the 60mm macro, you will be very disappointed! No offense meant to the 50mm, but the 60mm macro might be the sharpest lens I've ever used. There's several good reasons to get the 50mm 1.4 even if you have the 60mm, but "better sharpness" is not one of them.
XxDJCyberLoverxX Goldmember 1,139 posts Gallery: 30 photos Best ofs: 1 Likes: 148 Joined Oct 2009 Location: Shinjuku-ku, Tokyo, Japan More info | May 04, 2010 13:52 | #10 crcal wrote in post #10120140 The 60mm macro is very very sharp. It's a macro lens so it's slower to focus. But I'd take it any day over the 50mm f/1.4. Get the Sigma 30mm f/1.4 instead. x2. That's exactly what I did. Sigma 30mm + 60mm Macro. Yes the Canon is 2 stops faster, but I found the focal length to be too similar, and went with another f1.4 prime and am loving it! Daniel
May 04, 2010 13:52 | #11 Very interesting. I was under the impression that the 50mm was VERY sharp, but the 60mm macro wasn't as sharp. I guess I got some wrong info. Thanks everyone for your info! I was looking at the ISO12233 photos on some review site and here was the 60mm at 2.8:
and at 4.0:
And here was the 50mm at 2.8:
Looked much clearer. .
tkbslc Cream of the Crop 24,604 posts Likes: 44 Joined Nov 2008 Location: Utah, USA More info | May 04, 2010 15:46 | #12 You are probably comparing a 1Dsmk3 camera crop to a 40D crop. Taylor
May 04, 2010 16:09 | #13 Something seems wrong, doesn't it? If anything, the 60mm image should be larger, all other things remaining equal. 7D | 300D | G1X | Tokina 11-16mm f/2.8 | EF-S 17-55mm f/2.8 | EF-S 60mm f/2.8 Macro | EF 85mm f/1.8 | 70-200 f/2.8L MkII -- flickr
DeepPocket Goldmember 1,329 posts Joined Feb 2010 Location: Vancouver, BC, Canada More info | May 04, 2010 17:41 | #14 Permanent banYeah, it's always fun to shoot f/2 and wider 17 and learning..
hsmoscout Goldmember 1,166 posts Joined Oct 2009 Location: Camera Addicts Anonymous More info | Well I think you can't beat the 1.4 aperture. I mean if I had to decide between getting a less sharp, perfectly exposed shot in low light or a super sharp really underexposed shot, I would take the 1.4. If you find that you aren't using your 60mm or 50mm that much you can always sell it. That's what I love about camera stuff, it holds it's value very well. You could always get the 100mm macro if macro is the only thing you find yourself using the 60mm for. My Gear
| Latest registered member is griggt 872 guests, 140 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
