Thread started 04 May 2010 (Tuesday) 21:09
Please critique my lighting on these.
imahawki
May 04, 2010 21:09 |  #1
These were lit with a single strobe in an 86" PLM. I'm not sure I'm getting the ideal light placement but I'll provide more details after some comments (hopefully I get some).
1
IMAGE: http://www.cjpaulphotography.com/img/v3/p33656096-5.jpg
2
IMAGE: http://www.cjpaulphotography.com/img/v2/p444953034-5.jpg
Olympus OMD E-M10 | Olympus 25 f/1.8 | Olympus 45 f/1.8 | Olympus 75 f/1.8 | Olympus 9-18 f/4-5.6 | Olympus 14-42 f/3.5-5.6 | Olympus 40-150 f/4-5.6
My Zenfolio Gallery (external link)
Robert_Lay
May 04, 2010 21:34 |  #2
That is about as bland as you could possibly make it. Were you aware that it is shadows combined with the light that create the 3 dimensional look? Whatever you are doing it is too flat.
*************Studio Portrait Lighting**************​*
Tutorial on Studio Portrait Lighting Using Two Lights, with Emphasis on Rembrandt Lighting:
http://www.zaffora.com​/W9DMK/PortraitLightin​g.htm (external link)
or the downloadable PDF version at:
http://www.zaffora.com​/W9DMK/PortraitLightin​g.pdf (external link)
Also see this helpful reference:
http://en.wikipedia.or​g/wiki/Rembrandt_light​ing (external link)
Bob
Quality of Light (external link), Photo Tool ver 2.0 (external link)
Canon Rebel XTi; EF-S 10-22mm f/3.5-f/5.6 USM; EF-S 18-55 mm f/3.5-f/5.6; EF 28-135mm f/3.5-5.6 IS USM; EF 50mm f/1.4 USM; Canon Powershot G5; Canon AE1(2); Leica R4s; Battery Grip BG-E3; Pentax Digital Spotmeter with Zone VI Mod & Calibration.
imahawki
May 05, 2010 06:21 |  #3
Thanks Bob. The light was almost right behind the camera. I assume that is what lead to the flatness. I also think it was too low. Thanks for the references!
Laffctx
May 05, 2010 11:05 |  #4
Hope you dont mind. Thought I would adjust one of these a bit. I just brought the mids down a little, cropped out the pink belt I thought it was distracting me from the focal point, her face, took away some of the reds, pumped up the contrast a touch and used just a small amount of sharpening. See what you think. What a great shot you got of her. Nice picture.
Flo
Gimmie Some Lovin
May 05, 2010 11:27 as a reply to  @ Laffctx's post |  #5
I think this edit makes her too pink.it the lighting itself that needs to be fixed, not so much anything else?
SoftlySpoken
May 05, 2010 11:50 |  #6
I don't find #1 bland at all. I really like the subtle shading that is still visible in #1. However, I must agree with Robert_Lay on #2.
40D | Tamron 17 - 50 | Canon 50 1.4 | Sigma "Big Ma" 50 - 500
imahawki
May 05, 2010 12:01 |  #7
thanks... I like #1 a lot better as well.
crashthenet44
Location: Rails of the Lehigh Valley Line and Trenton Sub
May 05, 2010 12:08 |  #8
I'm with Bob and Flo. The lighting is too flat on both of these shots.
FLICKR (external link)
http://blogspot.vision​sfromphilly.com (external link)
50D | OM-2n | OM-4T | Hasselblad 500C/M | Yashica GSN | Yashica A | NO2. Brownie Model F
poloman
May 05, 2010 13:52 |  #9
Raise your light. Place another light below your camera. Adjust the ratio so that the upper light is twice as bright as the lower. 2:1 ratio...maybe a little less.
You can also use one light high to one side and the other near your lens. The lens light will be the fill (dimmer). Experiment till you get something you like. An incident meter will be invaluable for setting the ratios.
"All those who believe in psychokinesis, raise my right hand!" Steven Wright
imahawki
May 06, 2010 06:39 |  #10
Thanks... I was shooting for a single light shot but I think raising it and getting it off axis would have helped.
poloman
May 06, 2010 08:16 |  #11
You can use ambient or the sun for your fill or your main light. The trick is too make the difference between your main light and your fill light what you want.
1,818 views & 0 likes for this thread, 7 members have posted to it.
Latest registered member is RawBytes
1399 guests, 159 members online
