Thread started 05 May 2010 (Wednesday) 14:07
How does this person get rid of lens flare like this?
Striff
May 05, 2010 14:07 |  #1
Becker posted some of his before and afters and I was curious how you guys think he did this?
Here is the before
http://www.thebecker.c​om/bna/16.JPG (external link)
Here is the after
http://www.thebecker.c​om/bna/15.JPG (external link)
http://photosbycody.co​m/ (external link)My Blog (external link) | http://photosbycody.co​m/ (external link) | Follow me on Twitter (external link)
ssim
Joined Apr 2003
May 05, 2010 14:17 |  #2
Not sure exactly but I would think it took some work with selections, several layers and hue saturation for starters. I have had some lens flare as bad as this and it is alot of work.
You do know you aren't supposed to post others work. Provide the link only.
Tarzanman
May 05, 2010 14:21 |  #3
Saturation, contrast, vibrance, lightness.... maybe even curves (though I don't think messing with the curves or levels would have been necessary for the example you gave). There are more than a couple things to try that would probably give you decent results for the above example
Play around with each of those on adjustment layers and see what you can come up with. Even the exposure slider would probably go a good ways if you were inclined to layer the image
HankScorpio
May 05, 2010 14:22 |  #4
It's easily done by correcting the levels then applying a shallow S curve. It can be done way batter than they did as well. 2 minutes work at most.
My collection of boxes with holes (external link)
EXIF semper intacta.
Gort! Klaatu barada nikto.
gjl711
May 05, 2010 14:23 |  #5
Just hit "Auto Level" and it gets you most of the way there.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
FlyingPhotog
Cream of the "Prop"
May 05, 2010 14:23 |  #6
Unless the EXIF says otherwise, It's quite possible the After is actually the Before.
Lot easier to add a tinted veil than remove that much flare! ;)
Jay
HankScorpio
May 05, 2010 14:31 |  #7
gjl711 wrote in post #10127253 (external link)
Really don't. Auto Levels is a horrible thing. Learn to do it manually, it's not hard and the results are much better.
Anyway, Levels gets you from this...
... to this ...
I had to doctor the original to simulate flare to begin with as I'd never expose so badly ;)
sue.t
Gallery: 30 photos
May 05, 2010 17:00 |  #8
If Autolevels over does it, you can immediately use the Fade command to adjust the strength of the effect until it appears more reasonable.
Many commands in Photoshop can be faded immediately after the command has been completed -- maybe 50% of the correction would make a better result.
Tiberius
May 05, 2010 17:20 |  #9
You can also duplicate the layer and run autolevels on that. Whereas fade only works immediately after you use the command, you can adjust the opacity of a duplicate layer at any time.
My photography website!PHOCAL PHOTOGRAPHY (external link)
navydoc
Gallery: 236 photos
May 05, 2010 18:09 as a reply to  @ Tiberius's post |  #10
I just tried it and used auto levels then added a bit of contrast using curves. Finished with a bit of color correction for the gray point. Looks fine.
1,609 views & 0 likes for this thread, 9 members have posted to it.
469 guests, 139 members online
