Thread started 06 May 2010 (Thursday) 23:02
Good Lens For Architecture
painter4life05
May 06, 2010 23:02 |  #1
Hello
I need a good lens for architecture mostly 18th and 19th century.
Some Ideas I have are
10-22 MM
15-85 Is
Any others would be helpful.
Thank You
Michael D.
My Smugmug (external link)
Canon XSI~~18-55 IS~~70-200 F4L Non IS~~75-300 f/4-5.6 III Non IS~~50 f/1.8 II
xarqi
May 06, 2010 23:12 |  #2
Budget?
Where is your 18-55 IS failing you in this area?
SkedAddled
Gallery: 16 photos
May 06, 2010 23:16 |  #3
Consider also the Sigma 10-20 as an alternative to the Canon 10-22, if you want to save some money.
If you're able to spend a small fortune, look into Canon's TS(Tilt-Shift) lenses.
Xarqi mentioned a budget, which really would give others a better reference for recommendations.
Craig5D4|50D|S3iS|AF:Canon 28-135 USM IS|MF:Tamron SP 28-80|Tamron SP 60-300|Soligor 75-260|Soligor 400|Soligor C/D 500|Zuiko 50 f/1.8|others
Support this exceptional forum
Of course I'm all right! Why? What have you heard?!?
painter4life05
May 06, 2010 23:19 |  #4
500-750 dollars
I have not tried my kit lens for artitecture
SkedAddled
Gallery: 16 photos
May 06, 2010 23:26 as a reply to  @ painter4life05's post |  #5
Why not?
Seems to me you'll have a much better idea of your needs if you try out what you already have
before you go looking to acquire some fancy new lens.
gotak
May 07, 2010 00:19 |  #6
painter4life05 wrote in post #10136466 (external link)
500-750 dollars
You can easily get a tokina 11-16 which is a great UWA lens for the price.
Generally, the wider the better (in my experience) providing that there's as little distortion as possible. The 10-20 sigma is great in that respect. In that the majority of the frame is completely distortion free, but the edge takes a bend in it.
You might need something for low light if you plan to take the photos at night or when the light's failing. That's why I suggest the tokina 11-16 for it's f2.8.
http://bubble-trees.com/ (external link)
7D x2,, 50 f1.8, 11-16 f2.8, 17-55 f2.8, 70-200 f2.8 IS II, 100 2.8L, 430EX, 580EX, Di866, pixel king wireless TTL trigger.
chinchin7
May 07, 2010 01:05 |  #7
tokina 12-24mm great lens for it ! can use for FF dslr.
watt100
May 07, 2010 05:10 |  #8
500-750 dollars
why don't you at least try it before spending more money?
bohdank
May 07, 2010 07:23 |  #9
Check reviews that measure distortion and decide if any are worth buying more than others. Range would also be important. You can't always move sufficiently with an UW to make up for that. Also a wider lens does let you get closer so that obstacles in the periphery are moved behind you and not obstructing what you want to shoot.
fWord
May 07, 2010 09:00 as a reply to  @ bohdank's post |  #10
If you want ruler-straight lines and minimal distortion (which I assume is paramount with architectural photography), consider the Sigma 12-24mm f/4.5-5.6. It won't be as wide as other lenses that go down to 10mm, but the low level of geometric distortion is excellent, even if the lens is a little soft and needs f/11 or so to shine.
LightWorks Portfolio (external link)
Night Photography Tutorial: Basics & Minutiae (external link)
Gear List (Past & Present)
The Art of Composition IS the Art of Photography.
2,000 views & 0 likes for this thread, 8 members have posted to it.
1679 guests, 167 members online
